Author Topic: 69 mach 1 power brake distribution block  (Read 2496 times)
Offline cbrown
  • Silver Level Subscriber
« on: March 11, 2017, 04:46:44 PM »
Whats the story behind this ? (what my pen is pointing at)  Its on a 69 power brake mach 1 I am resotring..
chris
Offline 7Lscjracer
Re: 69 mach 1 power brake distribution block
« Reply #1 on: March 11, 2017, 05:28:31 PM »
That extra fitting is not original.
Maybe a male/female adapter for a hard line fitting with the wrong thread.
That distribution block port is for the hard line running to the master cylinder port closest to the booster.
Bought May '81, sold Sept '20
Offline cbrown
« Reply #2 on: March 11, 2017, 05:52:21 PM »
 I would agree it doesn't belong there but The fitting reads fomoco and has a c8aa-2b363-a   (hard to read My eyes are getting bad LOL)   but definitely ford part.  Never seen it before on cars I have done.
chris
« Reply #3 on: March 11, 2017, 06:31:52 PM »
I have one on my OE set up.  Sept. 68 Metuchen car.  Been a while but the use or function is not clear but it is some sort of reducer.  Going from memory; looking at the inside, of the C8AA 2B36-A fitting, it has a very small aperture for the brake fluid. 1/8" or less.  Brian
« Last Edit: March 11, 2017, 06:58:36 PM by Brian Conway »
« Reply #4 on: March 11, 2017, 07:02:04 PM »
I just happen to have my MPC (aka Ford Car Parts, 75 ed) out and C8AZ-2B363-A is shown as being used in 1969 on full size Fords, Fairlanes, Mustangs T-Birds and Falcons with power disc brakes and is called "Valve, Brake Pressure Impulse". No other applications or years.
You can download your own copy here - http://squarebirds.org/Manuals/1965/1965-72FordPartsTextCatalog/
« Reply #5 on: March 11, 2017, 10:41:57 PM »
Don't recall every seeing one of those nor recall reading a TSB article that indicated a change or fix related to one of those. Will go through the pictures though I expect to have the same findings
« Last Edit: July 02, 2020, 06:30:38 PM by J_Speegle »
Offline Armond
    • D'Agostini Restorations.com
« Reply #6 on: March 12, 2017, 04:40:50 AM »
I have one like that and others that don't have it.  I know I did a car in the past that had one and I don't know the reason why it had it. I thought it was odd.
MCA#31064
Offline cbrown
« Reply #7 on: March 12, 2017, 11:17:52 AM »
I don't really see what it does.  I first thought it was an adaptor for different threads but they are the same .  I guess I will leave it for now since it had it.
chris
Offline Vcode
« Reply #8 on: March 12, 2017, 06:39:43 PM »
« Reply #9 on: March 12, 2017, 11:06:28 PM »
Here is another post on the valve.
http://www.concoursmustang.com/forum/index.php?topic=1482.0
Very nice find   Vcode
And a big thanks to Marcus for posting it originally
« Last Edit: March 12, 2017, 11:28:29 PM by J_Speegle »
Offline Anghelrestorations
    • Anghel Restorations
« Reply #10 on: March 13, 2017, 02:35:55 AM »
I never did find the exact actual reason why some of these are included or not on certain Mustangs.  I have a box of distribution blocks and some have the impulse valve and some don't.  Running the brakes with or without never seems to make a difference.
Marcus Anghel
www.anghelrestorations.com
« Reply #11 on: March 13, 2017, 04:44:55 PM »
I haven't studied those impulse valve before so my question is does the orifice have a smaller diameter or the same? Other then the size of the orifice is there any inside (pressed in?) mechanical internals that can't be seen in the picture posted ?
« Reply #12 on: March 13, 2017, 10:15:13 PM »
Bob, I measured one of my examples with a drill rod, I got 0.075". Nothing inside, one piece brass.
