Author Topic: WTB Fuse Panel Mounting Screws  (Read 922 times)
Offline Linc
  • 67 Fastback GT - Clearwater Aqua
« on: February 27, 2017, 01:55:42 PM »
1967 Fastback GT Mustang. I cannot for the life of me find the screws that mount
the fuse panel to the firewall and would greatly appreciate if someone has them. Or
if they are available from NPD the part number, because I searched the catalog and
didn't find them, but I assume they MUST be there.
      1967 Dearborn Fastback - Clearwater Aqua - 7F02A120xxx
       I am Linc....  What more could you possibly need to know.
Offline BKnapp
Re: WTB Fuse Panel Mounting Screws
« Reply #1 on: February 27, 2017, 03:06:43 PM »
AMK would be a good place to look. However, they have a minimum order, so you may want to start a list of other missing fasteners.
https://www.amkproducts.com/Ford_Fastener_Kits.asp
« Reply #2 on: February 27, 2017, 04:22:58 PM »
Have you checked the library of this forum? There's a post called "Mustang Hardware Spreadsheet 67-68" with two files, on by part number, the other by application. In the application file, look up "Fuse . . ". There you will find part number, size and source references. With the part number, you can check AMK for supply.
Offline Linc
« Reply #3 on: February 27, 2017, 04:34:16 PM »
I have not, and didn't know that it existed. I will find it and check it out.
Offline Linc
« Reply #4 on: March 08, 2017, 09:31:56 AM »
Found them using the parts list, but $30 minimum order left me still in need. Local member has offered to send them to me, so I should be good. Thanks for all the help and direction.
Offline markb0729
  • South Jersey
« Reply #5 on: March 08, 2017, 10:01:19 AM »
Call NPD with the original part number.  They should be able to tell you if they carry them
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
