Author Topic: saving original tail shaft seal (manual transmission)  (Read 2294 times)
Offline Sean C. Gearty
  • 1969 San Jose GT
« on: February 26, 2017, 06:11:44 PM »
Anyone have any suggestions on removal original tail shaft seal? Looking to preserve my original seal and re-install after re detailing 4spd 1969 close ratio RUG-AE2 transmission.
Thanks!
Re: saving original tail shaft seal (manual transmission)
« Reply #1 on: February 26, 2017, 06:25:14 PM »
Have no idea of how you can remove it without damage so lets discuss attacking this from a different angle. Since there is little to the tailshaft housing other than the housing, bushing and seal is there anything wrong or it it too worn on either the bushing or seal?  If not I think an evapo rust soak, a good rinse and dry would work. Not sure how your treating the main case but you will need to match that final look but if your creative I think that will be doable also.
  • 1969 San Jose GT
« Reply #2 on: February 26, 2017, 07:21:19 PM »
Hi Jeff,
I am looking at phosphating (boil) then oil on both the tail shaft and gear box.
Yes the trans case and tail housing is clean enough for a good soak in evapo-rust.
It is the detail afterwards with the original seal still in place that concerns me leaving it in.
Offline rockhouse66
« Reply #3 on: February 26, 2017, 08:25:12 PM »
Sean
Here is how the original seal came out of mine.  Hope you have better luck!
'66 GT FB
  • 1969 San Jose GT
« Reply #4 on: February 26, 2017, 08:31:05 PM »
Hey Jim,
That is what I want to avoid.
The replacement rear seals are not like the originals, so hoping to figure out a way.
« Reply #5 on: February 26, 2017, 10:38:59 PM »
Hey Jim,
I have a friend that regularly sources a original appearing seal from the aftermarket that he talks about. You can call him and maybe he will sell you one or tell where to get one. Jeff at R+A Motorsports . 816 246 9094
  • 1969 San Jose GT
« Reply #6 on: February 27, 2017, 10:38:44 AM »
thank you for the contact Bob.
