Author Topic: 65-66 A/C unit drain hose hole  (Read 6063 times)
Online CharlesTurner
« on: July 22, 2010, 11:19:31 AM »
Anyone have a picture handy of a factory-made hole that the A/C unit drain hole goes through?  Looking for approximate location.  Evidently, early cars did not have the dimple like later.
Offline ChrisV289
Re: 65-66 A/C unit drain hose hole
« Reply #1 on: July 22, 2010, 12:37:53 PM »
From inside the car?  When I get home later tonight I can take a picture of the AC unit and hose and do some measurements...
2009 V6 Mustang Coupe
Offline rockhouse66
« Reply #2 on: July 22, 2010, 08:39:49 PM »
Crappy photo, but you can see the hole.  9/65 scheduled build San Jose car if you care.
'66 GT FB
« Reply #3 on: July 22, 2010, 10:48:39 PM »
Thanks!
Offline Charles Potts
« Reply #4 on: July 23, 2010, 12:01:43 AM »
Is the hole size supposed to be 1 inch?  I would love to see pics of the A/C unit in place showing the hose w/o cover and w/cover.  Also does anyone have a pic of what the hose looks like protruding from the underside?  Thanks for all the help!
PS  I'm missing the right side cover if anyone has one for sale.
Charles Potts
« Reply #5 on: July 23, 2010, 08:13:31 AM »
Yes, hole size should be 1".
Offline e093116
« Reply #6 on: July 23, 2010, 10:04:15 PM »
Thanks.
I needed this info too.
65 San Jose Fastback, May 15 build date
Offline 66RavenGTCoupe
« Reply #7 on: January 16, 2016, 05:29:39 PM »
Thats a great help.
Thanks for the link.
Dan.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
« Reply #8 on: January 30, 2016, 05:49:46 PM »
Charles Potts
National Parts Depot have them Charles.
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #9 on: January 30, 2016, 06:36:04 PM »
Hi All,
Looking to confirm air conditioner drain hole position for Sept 65 SJ convertible. I have several photos but am confused as to what is original and what is not. Did the factory hole ever change position? Also was the hose style ever changed? This is what I have as far as hose and what I think is the correct position so far.
Thanks in advance,
Daniel.
« Last Edit: January 30, 2016, 07:00:03 PM by 66RavenGTCoupe »
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline ChrisV289
« Reply #10 on: January 30, 2016, 08:06:47 PM »
That hose is correct for 66. They do not reproduce the 65 hose but what I did was use the PVC hose and made the hole bigger where it connects to the AC unit and took off the part number
Original topic here:
http://www.concoursmustang.com/forum/index.php?topic=10104.msg59924#msg59924
« Last Edit: January 30, 2016, 08:09:47 PM by ChrisV289 »
« Reply #11 on: January 30, 2016, 08:44:59 PM »
Only picture I could find in my files from the right angle
« Reply #12 on: January 31, 2016, 03:30:40 AM »
That info was exactly what I needed too Chris. Jeff, thanks once more for your help with the pic. Perfect for what i'm after. I did not even know of the two different hoses and hole placements until I read that. Much appreciated! (I am guessing that the 66 hole is lower down on the tunnel right?)
« Last Edit: January 31, 2016, 03:32:45 AM by 66RavenGTCoupe »
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #13 on: January 31, 2016, 02:47:00 PM »
That info was exactly what I needed too Chris. ................. Much appreciated! (I am guessing that the 66 hole is lower down on the tunnel right?)
Have found them in the exact same location (on San Jose cars) as in the picture I posted on 66's
« Reply #14 on: February 01, 2016, 01:19:11 AM »
Thanks Jeff ;)
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
