Author Topic: Partial Heater Box Removal  (Read 3548 times)
Re: Partial Heater Box Removal
« Reply #15 on: April 09, 2017, 03:44:10 PM »
Slightly off topic, but I use Scotch-Guard fabric spray on the paper fiber heater plenum. It's clear and water repellant. I think it adds a bit of "stiffness" as well. The spray should also be used on the fiber water shield located behind the instrument cluster on the left side, p/n C4ZB-14A099-A, 64-66 only.
« Last Edit: April 09, 2017, 07:16:43 PM by jwc66k »
Offline mjd 65
« Reply #16 on: April 09, 2017, 04:20:53 PM »
Slightly off topic, but I use Scotch-Guard fabric spray on the paper fifer heater plenum. It's clear and water repellant. I think it adds a bit of "stiffness" as well. The spray should also be used on the fiber water shield located behind the instrument cluster on the left side, p/n C4ZB-14A099-A, 64-66 only.
Thanks for the excellent suggestion, Jim.  It was very timely for me, because I finished installing my fresh air vent and was getting ready to reinstall the instrument panel water shield.  I'm off to pick up some Scotch Guard!
Mel
Offline Hipo giddyup
« Reply #17 on: April 09, 2017, 09:47:44 PM »
Not to high-jack a thread... but what is recommended for an original heater plenum cleaning/restoration?? I have a good used unit I want to restore for my upcoming 66' Dearborn coupe so since we are discussing heater box restos, I thought I would ask since it pertains to this area.
Offline markb0729
  • South Jersey
« Reply #18 on: April 09, 2017, 10:55:44 PM »
I know my heater box is not 100% concours correct.  For example, the bracket above the fresh air door that mounts to the cowl should be a natural metal finish.  Does anybody see other details that are not factory correct?  No offense will be taken.  It's all about the knowledge for the next project.  ;)
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
« Reply #19 on: April 09, 2017, 11:05:09 PM »
Looks ok to me other than the L bracket that holds the box up to the fresh air intake is normally natural metal, not black.
« Reply #20 on: April 09, 2017, 11:44:03 PM »
Believe we've discussed this before. The cardboard becomes stained, discolored and takes on multiple tones. Short of trying dye on it I have not found anything that addresses the issues. I have covered it in a water soluble glue to reshape and repair some areas and spread the glue over the whole surface and it tends to even out the look a fair amount but nothing perfect and not something I would suggest unless you have a test plenum to try it out on first.
Found a somewhat local retired guy that was thinking of doing repairs and restorations on these but he had not made the choice to jump into the market place yet.  His work looked pretty good though I had not seen what he started out with, only finished ones, they appeared to be presentable.
Like the Scotch guard idea for nice originals that are in good condition.
« Reply #21 on: April 10, 2017, 10:20:10 AM »
Thanks for the input Jeff. Let me get some pics of what I am starting with and I'll start a new post. It was sitting in a wood working shop for decades so it's covered in dust. I'll blow it off and wipe in down first to see what I've got. No way I can tell about any staining yet.
Offline amishtechnology
« Reply #22 on: April 17, 2017, 09:46:32 PM »
I see the control levers are two different finishes in this thread. What is the correct finish?
« Reply #23 on: April 17, 2017, 10:20:54 PM »
The pins that stick up for the cables to attach to should be natural.  The brackets for the cables to attach to should be black with natural clamps and usually phosphate hex screws with a slot so they can be used with a screwdriver.
Offline 65Ford
« Reply #24 on: May 13, 2017, 09:47:12 PM »
Mark,
For the record, what color was the date code stamp?
I hope no one minds me bringing up an old post and hijacking it:
I just pulled my heater box and it's silver.
63A  R  28  02K  51  1  5
5R09A142
« Reply #25 on: May 14, 2017, 12:28:18 AM »
I assume your car is a October 64 San Jose Build with a two speed blower motor (three wires).
Offline 65Ford
« Reply #26 on: May 14, 2017, 01:18:57 AM »
Oh!  I knew I forgot to mention the Mustang.  Yes, it's the fastback in my sig.  2-speed motor, three wires.  The same date code is also on what's left of the heater plenum.  It still has the tower clamps and what's left of the red stripe heater hoses.  Unfortunately, the original owner got over spray on the assembly when he painted the dash shell.
63A  R  28  02K  51  1  5
5R09A142
