Author Topic: 67 S code alternator mounting help  (Read 4795 times)
Offline bazza
Re: 67 S code alternator mounting help
« Reply #15 on: February 27, 2017, 08:29:15 PM »
IMHO its possible for a San Jose non Thermactor 390 to have been equipped with the larger dual mount (alternator and thermactor) plate and using the lower alternator mounting location with the standard (for thermactor 390) adjusting arm.  Seeing and have seen may too many of these brackets on unrestored San Jose non-thermactor 67's
Jeff, is it possible that all those cars were air conditioned??
67 Dearborn S code coupe Built 8/17/67
Offline 67gt390fb
« Reply #16 on: February 28, 2017, 05:27:31 AM »
Have found one possible answer about the mystery triangular mounting bracket hidden on Bob's GT500 pictures.  there is a 63, 64 Tbird  bracket, C3SE-10156-B, very similar to the C8AE-10156-B, but with no numbers stamped on it. Could be that one.
7R02S153xxx      12/15/66
« Reply #17 on: February 28, 2017, 06:12:44 PM »
no
Offline BKnapp
« Reply #18 on: February 28, 2017, 06:55:04 PM »
Please be easy on me, I hate even posing this question with my limited knowledge. How is the conclusion drawn that if it has AC and no smog, the alternator is typically mounted in the higher location? :-[  Based on page 77 and 85 of the Osborn engine manual, it looks to be in the lower position. I know the manuals aren't always accurate, but it just seems strange that no one can seem to locate the numbers and brackets for a non-smog AC car. They can't be that rare.
Offline bazza
« Reply #19 on: February 28, 2017, 08:18:06 PM »
Jeff, thanks for the definite answer, I'll rule out the A/C being a deciding factor.
67gt390fb, thanks for your effort researching this. It appears that the C3SE-10156-B can be used in either a high or low mount application with just a different adjusting arm.
http://www.network54.com/Forum/21142/message/1154357446/Master+Cylinder+And+ALT+Conversion
If Bob could confirm, at his leisure, that there is indeed no markings on the brackets he sees, it would go a long way towards solving this issue.
« Last Edit: February 28, 2017, 08:23:13 PM by bazza »
« Reply #20 on: February 28, 2017, 09:21:04 PM »
This is the most I can do for now. The car is sold and going to the UK in the next week or so with too many projects in front of this request to disassemble and reassemble before it leaves.If I come across another bracket I will be sure to share.
Offline bazza
« Reply #21 on: February 28, 2017, 09:56:38 PM »
Thanks Bob, I really didn't expect you to disassemble the alt to find out.
Any time you have one in your hands in the future is all I was hoping for.
Thanks again
Offline ceggar
« Reply #22 on: March 07, 2017, 09:45:56 PM »
I located a T-Bird bracket which I guess is numbered C3SE-10156-B(the bracket is not stamped)and it worked. I have also seen on E-Bay a C8AE-10156-B that is the same bracket. Not sure if they used the T-Bird bracket all the way up to 68 or there is a part number in between. Thanks for everybody's help.
Gary
67 GTA Fastback "S"Code
09/30/66 SJ
Online ruppstang
« Reply #23 on: April 01, 2017, 09:38:25 PM »
Here are some pictures of a Dearborn S code with AC and with out thermactor built 2-15-67.
Marty
Offline bazza
« Reply #24 on: April 03, 2017, 08:00:50 PM »
I ended up sourcing the same bracket that Ceggar did.
Looks like the pics Marty posted.
Offline BKnapp
« Reply #25 on: February 15, 2018, 04:12:36 PM »
Marty-
I suspect the car is now long gone. I don’t suppose you were able to verify a stamped number on the lower bracket?
I did come across this car that was restored in 1979 and believed to be original and unmolested prior to that.
« Reply #26 on: February 15, 2018, 08:13:44 PM »
Guess the pictures and comment beg for a follow up question. What makes you believe that the car was unmolested prior to 1979??
Offline BKnapp
« Reply #27 on: February 15, 2018, 08:33:20 PM »
That was the claim of the owner, who’s family owned it and did the “restoration” back in 1979.
« Reply #28 on: February 15, 2018, 09:47:15 PM »
Well they didn't retain a lot of what they saw. Given the mistakes made on detailing the creditability of the statement is in question IMO.
Offline BKnapp
« Reply #29 on: February 15, 2018, 10:27:34 PM »
I didn’t ask if they were trying for a Concours restoration. I believe the term the owner used was “freshened it up”. I suspect the wealth of knowledge today is a bit more than it was 29 years ago, but I can see your point.
