Author Topic: 67 390 GT distributor/carb  (Read 2306 times)
Offline TLea
« on: February 23, 2017, 01:58:58 PM »
Looking for correct engineering numbers for distributor and carb for Metuchen built 67 390 GT 4 spd. No AC, thermactor or PS. Late May 67 build
Re: 67 390 GT distributor/carb
« Reply #1 on: February 23, 2017, 02:20:02 PM »
Try the library.
Offline TLea
« Reply #2 on: February 23, 2017, 06:01:11 PM »
Thanks Jim. I have references from Ford manuals. As we know that isn't always what ended up in cars. Can someone relay their findings from original cars?
« Last Edit: February 23, 2017, 06:03:21 PM by TLea »
Offline bazza
« Reply #3 on: February 23, 2017, 06:03:46 PM »
Carb  C7OF-9510-A Holley list 3793
Distributor  possibly a C7OF-12127-H
67 Dearborn S code coupe Built 8/17/67
« Reply #4 on: February 23, 2017, 07:14:00 PM »
After 50 years, you expect original?
If I was a 67 judge, knew my distributors and carburetors, and saw something I knew was not specified, I would be suspicious. The "book" (read any documentation) may be incorrect, but what is found in a car isn't the best method.
On the other hand, if you come up with something different and have a source, I'll be grateful for some input and will update the info I've entered.
Offline TLea
« Reply #5 on: February 23, 2017, 11:47:12 PM »
I'm not saying ended up as in owner modified but what Ford did. A good example is 68 428 cj distributors. The books show 2 versions, I can name 5 that were used
« Reply #6 on: February 24, 2017, 12:18:14 AM »
If true, I would like the Ford numbers, a source and any other info you have.
Offline TLea
« Reply #7 on: February 26, 2017, 04:54:02 PM »
Thanks for the input Jim but with all due respect I don't have time to write a research paper right now, I just wanted some information
For those reading who this might benefit I have had reported to me from several known original cars a 67 S code 4 speed mustang uses either C7OE A or C. C is thermactor, all others A. The A matches with the C7OE H distributor. The C uses either C7OE F or G
Offline preaction
« Reply #8 on: February 27, 2017, 11:33:55 PM »
For those reading who this might benefit I have had reported to me from several known original cars a 67 S code 4 speed mustang uses either C7OE A or C. C is thermactor, all others A. The A matches with the C7OE H distributor. The C uses either C7OE F or G           You have not seen a C7OF-F for a 67 390 application ?
         You have not seen a C7OF-F for a 67 390 application ?  Sorry, I do see this in your post.
« Last Edit: February 27, 2017, 11:37:39 PM by preaction »
Offline SCJSTU
« Reply #9 on: June 13, 2021, 11:53:46 AM »
bringing this thread back up because I just bought a 1967 S-Code Fastback 4 speed.....needed same info
Thanks Tim!
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
« Reply #10 on: June 13, 2021, 01:54:05 PM »
Have you considered using the library on this Forum? It "might" have the information you need there.
Offline SCJSTU
« Reply #11 on: June 13, 2021, 02:12:56 PM »
Wow Jim.......have not been on here much last couple years but now I know about the library.....thanks thats great stuff!
« Reply #12 on: June 13, 2021, 04:44:26 PM »
See your signature shows a Jan 67 build but the other needed piece of info would be Thermactor or without. ;)
If your going to use the Library then you don't need to post it here unless you want us to provide - just sort of a reminder for the next poster
Offline SCJSTU
« Reply #13 on: June 13, 2021, 04:55:38 PM »
thanks Jeff will add to sig......
