Author Topic: Engine Block ID  (Read 2480 times)
Offline Skyway65
  • Gold Level Subscriber
Engine Block ID
« on: February 20, 2017, 07:18:51 AM »
Can anyone ID this block for me? C code, A code, K code  Anything?  TIA
Date code is "5A28"  Casting # "C5AE-6015-E"
« Last Edit: February 20, 2017, 07:59:06 AM by Skyway65 »
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline MattDoscher
Re: Engine Block ID
« Reply #1 on: February 20, 2017, 08:50:59 AM »
K codes would have 4 bolt mains so it's not a K code.  It could be an A or C code as they all including the K codes used the same 6015-E stampings.
Matt
Matt Doscher
5H25T582252
Re: Engine Block ID
« Reply #2 on: February 20, 2017, 12:32:53 PM »
That's a "K" code myth. All 63 thru 67 "K" code engines had two bolt mains.
Re: Engine Block ID
« Reply #3 on: February 20, 2017, 12:34:41 PM »
+1. k-codes did have thicker main caps but not 4-bolt.
Offline MattDoscher
Re: Engine Block ID
« Reply #4 on: February 20, 2017, 01:38:09 PM »
Your right, I stand corrected.  K codes had the heavier duty main caps.  If it was a K code block you should find a VIN stamped on the underside.
Matt
Matt Doscher
5H25T582252
Offline Skyway65
Re: Engine Block ID
« Reply #5 on: February 20, 2017, 07:57:45 PM »
The engine pictured is correct for a C-Code or A-code 289. A K-code engine block shares same casting (C5AE-6015-E), however was equipped with thicker main caps than the A-code/C-code engines. The main caps you have pictured are not K-code main caps.
Thank you for the responses.  I have a chance to buy this--thinking it might a K code diamond in the rough.  So much for it being my lucky day!  thanks guys.   ;) My recent experience has been with 200 6 engines.
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Engine Block ID
« Reply #6 on: February 20, 2017, 08:54:27 PM »
Even that stamping is under discussion as Metuchen "may" have forgotten a few.
Offline Hipo giddyup
Re: Engine Block ID
« Reply #7 on: February 21, 2017, 11:40:01 AM »
Unless I stand corrected, K code blocks also had screw-in oil gallery plugs and likely some sort of HP marking under the flywheel..??
Re: Engine Block ID
« Reply #8 on: February 21, 2017, 01:51:21 PM »
For the "plugs", some did, some didn't. I've been told it's an early (did) vs. late production feature.
The paint marking was supposed to be there, but in a rebuild it often gets washed away in the cleaning process. Your picture is a great discussion starter, and stopper. It would have to be there as an identifier as the VIN was stamped on the engine at the vehicle assembly plant, not the engine assembly plant.
Re: Engine Block ID
« Reply #9 on: February 21, 2017, 02:02:02 PM »
+1. Service replacement Hipo engines for example do not have a VIN stamped .
Re: Engine Block ID
« Reply #10 on: February 21, 2017, 04:01:19 PM »
With so many "should haves" it sounds like an unstamped block with the right part number and date could pass as a HIPO? A block that was "missed" in stamping, perhaps never grease/paint marked, or as you've said with these markings washed away during a rebuild, this block in the topic ,though not likely, could be passed off as the real thing.  Its the "common" pieces of the puzzle that we all look for, main caps, balancer, counter weight, rods, vin stamping, etc. thinking its a correct HIPO.
Always learning something new here.  ;)
Offline sgl66
Re: Engine Block ID
« Reply #11 on: February 21, 2017, 04:24:06 PM »
Can confirm my block was not stamped nor transmission. I bought car from original owner in 1980 with original paperwork and all original dated Hipo parts and service records. Also reconfirmed with original owner a few years ago that drivetrain was not replaced. No screw in plugs either
Offline C6ZZGT
Re: Engine Block ID
« Reply #12 on: February 22, 2017, 03:28:07 AM »
Where and when did "screw in frost plugs" ever become hi-po lore ? And does anyone have pics ?
Sorry ,scratch that I just reread the post and saw they said oil galley.
« Last Edit: February 24, 2017, 12:55:13 PM by C6ZZGT »
Brian
66 GT Coupe 6R07A143871 owned since 1983
40+ yr parts man , over 25 with Ford.
Re: Engine Block ID
« Reply #13 on: February 22, 2017, 12:39:02 PM »
Probably due to later Boss cars having it... just a guess.
Re: Engine Block ID
« Reply #14 on: February 22, 2017, 04:29:13 PM »
All it takes is someone putting it in an article, a post online, or any of a number of ways. Same with 4 bolt mains, screw in oil plugs .......
Recall overhearing a comment at a show years ago that went something like "guy doesn't know anything ....didn't even know that Shelbys were sent from San Jose to Shelby with 6 cylinders when they ran short of engines and they put in the K codes at the Shelby plant"  ::)
Who knows where the stuff starts but would like to think that they are just incorrectly informed and not intentional
