Author Topic: Parking brake cable spring replacement  (Read 2651 times)
« on: February 16, 2017, 09:17:47 PM »
I have a great pair of parking brake cables, except that the return springs were cracked.  Strange that everything else was nice but that is the case.  I can't slip the springs over the end fitting.  Any repair suggestions?  I'm thinking I might be able to clear the fitting from a spare with a drill bit, cut the one off the new cable, then move the donor over and "crimp" it on with a press and die.   Thoughts and recommendations appreciated
Offline 1966KGT
Re: Parking brake cable spring replacement
« Reply #1 on: February 16, 2017, 11:10:26 PM »
without seeing the other end, if it is a ball, maybe you can cut ball off with dremel tool, remove cable, replace spring, slide cable back thru conduit, then "birdcage wire slightly", then clean wire with brake cleaner and make a mold with wood that you could melt lead into and pour into mold? crude but a possibility? in my line of work we re- end cables using this technique, but were using 1" cable, 40,000 #pull,  works well.
1966 K GT, BUILT 11/08/65 4 SPEED, SAN JOSE CAR, 1969 Mustang convertible, 1970 MACH 1, 1963 GALAXIE Q code Fastback, 1966 mustang t code coupe, fuel injected
« Reply #2 on: February 17, 2017, 05:43:28 AM »
The other end is a ball - thanks for the idea, will look into that.
« Reply #3 on: February 17, 2017, 01:05:42 PM »
I would think at first thought lead being soft would not stand up under use on the thinner Mustang cable let alone a 1 inch cable with a possible 40,000 #pull but have never tried it on a Mustang cable let alone a 1" cable.  ;D I would have thought steel like original(Mustang)
« Last Edit: February 17, 2017, 02:25:09 PM by Bob Gaines »
Offline mtinkham
  • That'll be easy
« Reply #4 on: February 17, 2017, 02:02:17 PM »
Can you thread the spring onto the cable? Hold the middle of the spring 90 degrees to the cable and start "threading" or winding the spring around the cable, then work the other half of the spring?
« Reply #5 on: February 17, 2017, 04:27:11 PM »
At first I thought you were saying to start a new thread  ;) will try that tonight and report back.
« Reply #6 on: April 25, 2017, 05:04:18 PM »
"How to keep the Concours crowd in suspense!" (+2-months later)  :P
« Reply #7 on: April 25, 2017, 06:03:49 PM »
Darn thought I did that.  It was uneventful, or in other words I was able to "walk" the spring right onto the cable.  I took some pics but need some time to load them up with some descriptions.  Since I have some high priced consultants at work this week I'm doing 11-13 hour days so if you are looking for pics the suspense will be a bit longer☹️
« Reply #8 on: April 27, 2017, 06:37:49 AM »
Here are the pics, the first as I started to thread the spring over the cable, the second as the end results.
Thanks to mtinkham for the suggestion
Offline mtinkham
  • That'll be easy
« Reply #9 on: April 27, 2017, 01:42:48 PM »
I have received so much help from this site...first time I was able to help someone and happy to do so.
