Author Topic: WTB 67-69 nos ford tie rod ends and sleeves  (Read 1521 times)
Offline 68GT/CSconvmod
« on: January 30, 2017, 04:08:30 PM »
Without grease zirks in ends.
Troy
« Last Edit: January 30, 2017, 08:19:37 PM by 68GT/CSconvmod »
Re: WTB nos ford tie rod ends and sleeves
« Reply #1 on: January 30, 2017, 04:18:15 PM »
what year?
Outers only, inners only, or both?
« Reply #2 on: January 30, 2017, 04:20:22 PM »
Troy
Any reason why you wouldn't want assemblyline parts that have been restored to look NOS? Many of your NOS parts are going to have aspects that will be different then assemblyline that you did not cover in your criteria .
Re: WTB 67-69 nos ford tie rod ends and sleeves
« Reply #3 on: January 30, 2017, 08:18:57 PM »
outer/inner / sleeves.
A friend wants assembly line with no grease zirks for a concourse restoration. 67-69
Troy
« Reply #4 on: January 31, 2017, 02:22:42 PM »
numbers are.
C7ZZ-3A130-A  outer
C7ZZ-3A131-A  inner
D0oZ-3A130-B  outer
D0oZ-3A131-B  inner
Sleeves C2AA-3310-A
No grease zirk please.
Troy
« Reply #5 on: January 31, 2017, 04:29:30 PM »
numbers are.
C7ZZ-3A130-A  outer
C7ZZ-3A131-A  inner
D0oZ-3A130-B  outer
D0oZ-3A131-B  inner
Those are service part numbers and, as such, may (or should) include zerk grease fittings. Just a heads up.
« Reply #6 on: January 31, 2017, 04:37:48 PM »
numbers are.
C7ZZ-3A130-A  outer
C7ZZ-3A131-A  inner
D0oZ-3A130-B  outer
D0oZ-3A131-B  inner
Sleeves C2AA-3310-A
Troy
After you read reply #5 re read reply #2 for explanation why your request is not going to get the results you wanted most likely . FYI The D00Z parts (1970 for those reading that aren't aware)will most likely will have the removable rubber boot where the aseemblyline 67-69 typically have the boot with the metal ring pressed on .
« Reply #7 on: January 31, 2017, 05:53:33 PM »
So far have found a full set no zirks with C7ZZ  interested in more if possible.
Looks as if Jeff wants a 70 set  D0OZ  outer for 2  &  D0ZZ inner for 2 and a set of sleeves.
Troy
