Author Topic: starter restoration stamp  (Read 2815 times)
Offline 1966KGT
« on: January 18, 2017, 05:14:54 PM »
Is there someone who can stamp my SJ 1966K starter, build 11-8-65, after restoring insides?
Re: starter restoration stamp
« Reply #1 on: January 18, 2017, 07:24:23 PM »
Sure.  Send it to me when you get to that point . PM me for ship to details
Offline 1966KGT
« Reply #2 on: January 18, 2017, 07:49:19 PM »
Thank you Mr. Gaines, do you have a picture of a restored unit as mine has been possibly spray bombed. I am taking it down this weekend. Not sure what the "brush" band looks like [black or gold zinc] and the nose should be natural?
« Reply #3 on: January 18, 2017, 08:42:26 PM »
There are a number of threads on the subject so you can use the search feature . Make sure the nose is not painted and I will do the rest . It will not take that much more for me to do. I would suggest making up a paper gasket to go under the band on the end. that is if you want it assemblyline looking as the rest of the details.  Gasket paper is best . It should stick out just a little from the edge . You can use the metal band as a pattern.
Offline 1966KGT
« Reply #4 on: January 19, 2017, 09:04:13 AM »
Thank you, I will send pm when ready to ship.
« Reply #5 on: January 19, 2017, 12:39:52 PM »
If the picture is of yours then it is most likely not been rebuilt  given the faded stamping. If not just to be on the safe side can you post a couple pictures here to confim you have the correct nose ? Rebuilds sometimes substitute parts with other years as long as they work and the nose is the most common replaced.
Offline 1966KGT
« Reply #6 on: January 19, 2017, 02:56:32 PM »
Pics attached, sorry for zip file, I suck with computers
« Last Edit: January 19, 2017, 03:07:14 PM by 1966KGT »
« Reply #7 on: January 25, 2017, 02:38:51 PM »
As mentioned there is one or two threads were we looked at and discussed the stamp design originally used on the earlier (64-68) starters verses the 67- 73 stamped in metal style. The design of the "decal" turned out to be different from the original (likely taken from a later service replacement) but bottom line is yes you can get a starter stamped with an approximate or appropriate date from your car.
« Last Edit: April 01, 2023, 02:41:16 PM by J_Speegle »
