Author Topic: 69 Strut Rod Bushing/washers ?  (Read 6169 times)
Re: 69 Strut Rod Bushing/washers ?
« Reply #15 on: June 07, 2018, 05:58:36 PM »
what is/was wrong about your original washers? i do not understand the need to replace the washers unless they are damaged. they can be refinished & you will have the proper shape.
Offline Brian Conway
« Reply #16 on: June 07, 2018, 06:05:06 PM »
I don't have original washers.  The washers I do have, on the car, are posted in the earlier discussion and I believe are MOOG aftermarket .  I do fortunately have the original hardware.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #17 on: June 10, 2018, 05:19:13 PM »
Got lucky and located a set of OE 69 strut rod large retaining washers.  One pair is smooth faced and the other pair has witness marks from a nut.  The set up on the car now uses a washer behind the nuts front and rear.  Shop diagram shows nuts only no washer ?  Smooth retaining washer and smaller nut in rear position and retaining washer w/witness marks and large nut up front ?  No washers behind the nuts ?  Brian
« Last Edit: June 10, 2018, 05:35:26 PM by Brian Conway »
San Diego, Ca.
« Reply #18 on: June 10, 2018, 07:53:12 PM »
Just the large retaining washer and the nut just like the illustration.
