Ross,
The quick answer is yes. You might consider scraping away some of the undercoating and verifying the color. Primer was not under tight color or shade control. There are a lot of variations. Overspray is common, from the pinch weld, fender wells, engine compartment for black, and then body color in some areas too. It was done quickly so be a bit sloppy. There are a lot of picures on the subject so use the search feature.
