Author Topic: New Pony in the stable.?  (Read 1213 times)
Offline Josep
« on: January 12, 2017, 04:18:53 AM »
Hi guys, I am considering the purchase of a new pony to my stable. It is a late 65 convertible 200 that looks very good and is almost ready to go, it just need the underneath reinforcement panel, the adjust of one door and a front brake leak. It's very stock but has some parts that are not original to the car like the fog lights.. Even so, the car looks in very good shape, with all the floor panels being replaced.
The question is, some PO repaint it and took no care of the door plate, and resprayed it all over.! Is there a way to remove the paint and bring the original plate again to life..? I know I can get a repo, but wanted to know if there's a way to recover it. Some pics attached...
Josep
« Last Edit: January 12, 2017, 04:23:44 AM by Josep »
Re: New Pony in the stable.?
« Reply #1 on: January 12, 2017, 05:33:50 AM »
......Is there a way to remove the paint and bring the original plate again to life..? I know I can get a repo, but wanted to know if there's a way to recover it. Some pics attached...
Depends on the condition of the tag before they painted the car, what kind of paint and prep they did before painting it. Often in my experience I was able to carefully ship away the body color since they had not sanded or prepped the surface much of it was simply sitting on the tag.
Just what has worked for me - of course if the tag was well worn before the paint its still going to, at best, be worn after you remove the paint
Offline Josep
« Reply #2 on: January 12, 2017, 08:26:07 AM »
And if that was the case, how did you remove the body color..? Which product did you use..?
Josep
Offline ChrisV289
« Reply #3 on: January 12, 2017, 08:59:00 AM »
Try gasoline on a rag first. That might get rid of the top layer. Paint stripper might go through and remove the black or gray on the dataplate its self
2009 V6 Mustang Coupe
Offline Josep
« Reply #4 on: January 12, 2017, 09:15:26 AM »
Right, I will try it in case I go ahead with the vert.
Josep
Offline GT500KR
  • Charlie Ping
« Reply #5 on: January 12, 2017, 09:17:36 AM »
   As Jeff stated, typically little or no prep work is done to promote adhesion by those who spray over hardware and data plates.
   Try wiping it with alcohol so the paint is clean, then apply tape or a bumper sticker (strong adhesive) to the plate. Really rub it on to make it stick. Leave it overnight, or longer so it bonds well. If you're lucky, some, or all of that paint will come off when you remove it.
   High pressure air and a blow gun can work as well. You might blow some of the paint off the door at the same time. ::)
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 JalapeƱo Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline Josep
« Reply #6 on: January 12, 2017, 09:20:21 AM »
Thanks man.! Good tips also.! Now I have to decide what I do.! Solution for the door tag paint is solved..!
Josep
« Reply #7 on: January 12, 2017, 03:16:46 PM »
Josep
Normally would find a defect in the coat (like it appears there may be one in the lower left) get under the paint with a small nylon or wooden tool and start carefully pushing and proding until you get a section to lift or chip off. Get creative, change angles and a little at a time - unless a big section chooses to give way all at once. Metal tools or a heavy hand will likely produce damage to the surface or the printed nature of the original tag if any is still there
Could always remove it and treat it like others have offered. Just get some new rivets and replace it once done
Sure there are plenty of ways just what has often worked for me
