Author Topic: Pinion yoke U bolts  (Read 666 times)
Offline FXguy
    • Early 64 June K Convertible Restoration
Pinion yoke U bolts
« on: January 08, 2017, 04:40:21 PM »
Noticed two type of U bolts on 64 1/2 K codes.  One of these came off a 4E4 dated differential housing and the other off a 4F5.  One on the right has beefier shoulders in addition to having the circular indent on the top.  My 1964 parts and accessories manual show the same part used on 9 inch and 8 inch rear ends.
Anyone know if one or the other is correct for the time period?
-Scott
« Last Edit: January 08, 2017, 04:48:26 PM by FXguy »
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
Re: Pinion yoke U bolts
« Reply #1 on: January 08, 2017, 05:10:56 PM »
........ My 1964 parts and accessories manual show the same part used on 9 inch and 8 inch rear ends.
Not sure if I have anything to help specifically but just as a reminder the catalog will only show what Ford carried to service the part not what was originally used.
Sure some of the early K code guys should be offer some observations
Offline FXguy
« Reply #2 on: January 09, 2017, 03:36:52 PM »
Right Jeff, many instances of production parts being serviced by others.  I'm still hoping that someone will be able to sort this out.
Thank you,
-Scott
Scott McMullen
