Author Topic: Door Panel Removal - 69 Deluxe/Mach I style  (Read 1486 times)
Offline ddonzella
« on: December 31, 2016, 01:28:22 PM »
Happy New Years! I have a 69 Shelby with deluxe door panals. Before I loose my temper and rip the damb thing off, can someone tell me how to release the center retaining bracket which is behind the door light assembly? (Thank for allowing me to vent)
« Last Edit: December 31, 2016, 01:57:36 PM by J_Speegle »
Re: Door Panel Removal - 69 Deluxe/Mach I style
« Reply #1 on: December 31, 2016, 01:59:11 PM »
Did you remove the screws at the hand grab area of the door panel?
Offline ddonzella
« Reply #2 on: December 31, 2016, 02:48:47 PM »
Not seeing any screws other than the two that hold the metal light cover on.
Offline ddonzella
« Reply #3 on: December 31, 2016, 02:54:26 PM »
Passenger panal had no center fastener. Came off easy.
Offline ddonzella
« Reply #4 on: December 31, 2016, 03:14:31 PM »
Ok, the center is held in by two compression studs. The door panal has a push on clip behind metal door skin. Simular to how some exterior badges are fastened in place.
Offline 69GT350H
« Reply #5 on: December 31, 2016, 04:45:16 PM »
At the bottom of the door pull cup, there should be a rubber insert that lifts out exposing a screw.
« Reply #6 on: December 31, 2016, 10:41:09 PM »
+1 - Just the 65-67 deluxe door panels ;)
