Author Topic: 1966 hi po fuel pump  (Read 2408 times)
Offline 1966KGT
« on: December 25, 2016, 02:27:19 PM »
what would a accepted fuel pump be for a 66 sj k code built 11/06/65, 4201's are out there! date code?
Re: 1966 hi po fuel pump
« Reply #1 on: December 25, 2016, 03:13:12 PM »
The date code you should be interested in would be 1 to 4 weeks prior to the engine assembly date. The pictures show where it's located. Fred Ballard fredsclassics@hotmail.com would be a good starting point to find one. Note the fuel pump in the first picture. Fred rebuilt it.
« Reply #2 on: December 25, 2016, 04:04:03 PM »
You can consider yourself lucky to find one at all let alone one with the correct date code. They are rare. Just thought I would mention it  so if you are lucky enough to find one but doesn't have the correct date code think that you will easily find another to choose from . It could happen and I hope it does for you but wanted to make you aware. FYI date codes are only relevant in the most difficult of judged classes. I have seen way to many fixate on a date code for a particular part and forget about many other more easy to do details throughout the entire car. Best of luck with your build.
Offline 1966KGT
« Reply #3 on: December 26, 2016, 04:31:49 PM »
THANKS!
Offline markb0729
  • South Jersey
« Reply #4 on: December 27, 2016, 02:03:06 AM »
<snip> Fred Ballard fredsclassics@hotmail.com would be a good starting point to find one. <snip>
Yup Fred is your guy.  About 2 years ago, I sold a CARbureTER 4201S, Date Code 4A6A (1/4/66) to him.  Believe it or not I came across this fuel pump by accident.  I bought a worn out 64, 260 with C4 transmission from a guy in Delaware to get the auto trans kick down linkage that was missing on my 65.  I tore down the 260 to part out and low and behold there was an authentic 4201S fuel pump!  I have no clue how that fuel pump got on that motor.  Sold the fuel pump for much, much more than I paid for the engine and trans.  Be prepared to pay big bucks if you find one.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
