Author Topic: Turn Signal Switch Part Identification  (Read 4770 times)
Offline Mark69Sportsroof
« on: December 12, 2016, 11:45:19 PM »
Hi Everyone,  I just pulled my turn signal switch and can't locate the part number.  I don't know if its on the actual part or the wire loom tag.
Any ideas or suggestions?  Thanks Mark
« Last Edit: December 12, 2016, 11:50:04 PM by 69mustang73mach1 »
Mark
1969 Ford Mustang Sportsroof, 390-4V
Dearborn built on Oct 31, 1968
1973 Ford Mustang Mach 1, 351C-4V
Dearborn built on Oct 31, 1972
Re: Turn Signal Switch Part Identification
« Reply #1 on: December 13, 2016, 06:29:02 AM »
From a NOS Autolite switch service replacement,  and what I recall on other original switches, you should find a tag wrapped around the harness closer to the switch. See image of my 67 tilt column switch.
Since posted in the Mercury (non-Mustang) section, I assume you are looking to find a part number for your 68 Park Lane (you did not specify)
Engineering number on your Mercury will follow the typical Ford numbering process. Cxxx-xxxx-x pattern.
For what it is worth, the number off the tag will USUALLY NOT match the PART NUMBER Ford used for servicing the switch. For example, the switch pictured below has a tag with engineering number of C7ZA-13B302-E while the Autolite service box has part number C7ZZ-13341-E on it (some discrepency on this since the suffix "E" is hand written over a "-02") The point I am trying to make is you need to source your "most correct" Service PART NUMBER from a Ford Master Part Catalog (MPC), and unless the catalog directs you to look at identifying "tag" number, your REPLACEMENT number should be easily found in the most "period correct" MPC you can locate.  Later MPC sources will find the most recent number Ford gave to the service replacement part number, usually a more "generic" fitment service part.
« Last Edit: December 13, 2016, 07:00:33 AM by 67gtasanjose »
« Reply #2 on: December 13, 2016, 10:32:00 PM »
Thanks Richard.  It is for the 68 Mercury Parklane.  I have looked all over the plastic pieces but no part number visible.  The tag number being different makes sense.  The search continues.  Thanks again for the information.  Mark
Mark
