Author Topic: 67 Remote view mirror glass date code  (Read 4504 times)
Offline preaction
« on: December 12, 2016, 08:57:03 PM »
I looked through the library's car glass date code info and unfortunately remote rear view mirror glass date codes were overlooked. The date code on the mirror in question reads  2-DMI-7 normally I would read this as month first then year, 2- February and 7- being 67 since this came from a 67 built (4/28/67) car. The reason Im asking about this is the person I talked to about this interpreted the date as year first and month second, 2-72 and 7-july. I hope Im right thanks Paul. ;)
Re: 67 Remote view mirror glass date code
« Reply #1 on: December 12, 2016, 09:37:42 PM »
I believe it is a Feb 67 date code . I know some restorers that will take a correct dated glass and transfer it to another body.
Online ruppstang
« Reply #2 on: December 13, 2016, 12:02:38 AM »
I have done it, not easy but do able. Worth the effort to have a correct date coded glass.
Offline Ralf
« Reply #3 on: December 13, 2016, 06:45:19 AM »
Would not confirm. Why?
Because I have a mirror 4 DMI 3. Would mean April 63 according to above.  But can't be. The mirror has the shape of a 67/68 car.
Even year first, month second doesn't make sense to me.
Imho there  must be another specification behind.
Thx Ralf
« Reply #4 on: December 13, 2016, 07:08:51 AM »
Thx Ralf
I'm NOT an expert on decoding glass or mirror dates but it seems that the "decade" of production of these items is not coded into the date code so if your "decoding process" is correct, it could be possible the one you are looking at is a Service Replacement part.
Online ruppstang
« Reply #5 on: December 13, 2016, 09:10:29 AM »
+1 Service replacement parts were produced in to the 90s
« Reply #6 on: December 13, 2016, 03:38:13 PM »
Thx Ralf
In other words your example could be 73,83 or 93 . Not to say a NOS piece with a 7 or 8 couldn't be 78,88 etc. The code with a relevant number is better then one with a no way it's relevant number.  I mentioned the process to switch mirror glass as a alternate way to get a date coded mirror so those looking don't get too frustrated. I would like to say that sometime people get too evolved with the nuance details and disregard the big picture or more visible aspects.
« Last Edit: December 13, 2016, 03:42:46 PM by Bob Gaines »
« Reply #7 on: October 06, 2017, 10:45:44 AM »
I just obtained a 67 DS mirror (has C7AB17743B mirror base and 67 style adjusting knob) with 6JC7 date code
Decipher the code please? So far, I am confused with what was shared earlier in this thread. (want to wrap my head around mirror codes better)
Offline Brian Conway
« Reply #8 on: October 07, 2017, 03:35:36 PM »
 author=67gtasanjose
FWIW; the OE dual racing mirrors on my 69 are date stamped 8JC8 and decode; 1968  September.  The C8 is the prefix to the engineering number.  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #9 on: October 07, 2017, 05:34:46 PM »
author=67gtasanjose
Following the decipher you describe, it seems odd that the numbers on the several "JC" mirrors I have seen so far are all SEPTEMBER dates (or is it?). If others concur, this code on my mirror would be 1966, September C7 engineering. This fits well to my need but I have t wonder why there are other 1967 examples like  1 DM1 7 OR 4 DM1 3
I was beginning to think there were two suppliers. JC and DM
Maybe too complicated to understand at this point in time...
« Reply #10 on: October 11, 2017, 11:59:43 AM »
... I know some restorers that will take a correct dated glass and transfer it to another body.
So, going along these lines of discussion and using a date coded glass removed from an original, I noticed the "etching" of the code, at least in the example I am working with, is etched into the "silvering" layer, not on the outer surface. (there was previous conversations on "etching" a code ONTO a replacement glass, similar to what is done on windshields).
I will upload a picture of the etching with a few "backlight shots" to show what I am trying to write out.
Offline dkknab
« Reply #11 on: April 24, 2024, 09:49:53 PM »
Very old thread but I'm trying to get a handle on the etching on my side door mirrors.
My driver side is etched 12-DMI-7
My passenger door mirror which I have no documentation confirming when it was installed is 6-DMI-7
The base my passenger mirror is C7AB17743 A. Below that is 15 15 53 1
What do these numbers tell you?
David Knab
289 2V, AT, PS
Nugget Gold Interior
Offline dkknab
« Reply #12 on: April 25, 2024, 01:12:31 PM »
I took off my driver side mirror. It put up a good fight because the rear screw spun in place since the insert was loose. After taking off the inside door panel and with a struggle, I was able to get the rear nut out. I'll have to determine how to secure the rear insert.
But my point is the base of the driver side mirror is marked the exact same as the passenger side. C7AB17743 A and below that 15 15 53 1
Does that mean they are from the same batch of mirrors of were all mirrors for multiple years marked the same?
David Knab
289 2V, AT, PS
« Reply #13 on: April 25, 2024, 03:14:30 PM »
ran into the non sticking nutsert problem while installing a visor over the windshield on my truck. used a small dab of j-b weld to hold it still. i did not use the quick type. worked quite well.
Offline Murf
« Reply #14 on: April 25, 2024, 05:33:54 PM »
Mirrors can be identified by understanding a few simple rules.  If the mirror is marked with "DMI" it was supplied to Ford by "Donnelly Mirror INC".  The first number identified the  month  produced.    The DMI is Donnelly company, and the second number gives the year.  There was a second supplier to Ford named "AJAX" and the mirrors they supplied were coded in the following way:  First symbol will be a letter of the alphabet indicating the MONTH (January would be indicated by "A" . "B" would indicate February and so on)  The letters JX will follow the month, and the last two numbers will indicate the year.  (67)  so you would see a mark such as A-JX-68 for a mirror coded January of 1968 and manufactured by Ajax  INC.  Hope this in some way helps you  identify at least two sources of outside mirrors and the manufacturers marks and date coding
John Murphy
