Author Topic: 65 San Jose battery post shield question - Oct 64  (Read 1902 times)
Offline 66RavenGTCoupeAgain
« on: December 10, 2016, 08:44:09 PM »
My Oct 64 SJ has no rubber battery post shield at all. No staple holes or anything. Would this be normal?
« Last Edit: December 10, 2016, 10:25:25 PM by J_Speegle »
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Re: 65 San Jose battery post shield question - Oct 64
« Reply #1 on: December 10, 2016, 10:26:15 PM »
Would not expect to find one that year and plant. Your positive battery clamp would have had a red rubber shield over the connection and post
« Reply #2 on: December 11, 2016, 12:15:58 AM »
By the book, the rubber shield was a 66 application. None on a 65, which is the way my May, 65 San Jose GT Fastback is equipped.
« Reply #3 on: November 29, 2020, 03:11:45 AM »
Do we know when they started using them in SJ?
« Reply #4 on: November 29, 2020, 05:57:15 PM »
Looks like job #1 for 66 as best I can tell from what I have. A better question for you might be are there other unrestored examples that didn't have driver side inner fender without the holes for the plugs and no evidence of staple holes? Green cars are ones observed or reported to have no staple holes or pads in place with staples. Underlined examples were ones with holes for staples or pad in place with staples
6R101702 Aug 26 scheduled date
6R1124xx
6R1138xx (reported)
6R1174xx
6R1206xx
6R1206xx (reported)
6R1207xx
6R1209xx
6R1225xx
6R1253xx
6R1271xx
6R1271xx
6S129xxx
6R1306xx
6R1306xx
Focused only on an area before and during were there appears there were possibly issues with staple machine (as we've seen at Dearborn in 69 production) where some cars got them and others did not. Guess there was no back up plan or a second choice if the machine was not working and this may have brought forth the idea of changing the retaining method (to the plastic push pins) to eliminate the need for the stapler and any problems.
« Last Edit: November 29, 2020, 11:14:02 PM by J_Speegle »
« Reply #5 on: November 29, 2020, 08:23:44 PM »
Interesting stuff. Thanks Jeff.
Offline Mustangklaus
  • CB-In Training
    • 64½ - 66 Mustang Restoration page of Klaus
« Reply #6 on: January 19, 2021, 05:19:58 AM »
This is the first one in my registry:
6R07C100003   65A   M   66   16H   89   6   6   C   R   66   100003
Klaus Schaefer
www.early-mustang.com
Klaus Schaefer
Certified MCA Judge for  64½ - 66 Mustangs
« Reply #7 on: January 19, 2021, 06:05:29 AM »
Are you reporting that this car had a shield in/on it? If so, while your reporting, how was it attached?
