Author Topic: 1969 san jose F code shield caliper  (Read 2964 times)
Offline m.b.spuur
« on: December 06, 2016, 06:11:01 PM »
hello are there some one there know what the finish for the factory is on the shield caliper and the strut rods . thanks
Re: 1969 san jose F code shield caliper
« Reply #1 on: December 07, 2016, 10:39:09 PM »
Shield = semi-gloss black
Strut rod. Darkened heat quenched steel. If you do a search you will find ways others have discovered to achieve this finish in their restorations
« Reply #2 on: December 08, 2016, 12:16:52 PM »
jeff I think he means caliper shield (silver)   not rotor shield (black) but not sure what he is asking.
« Last Edit: December 08, 2016, 12:19:47 PM by specialed »
« Reply #3 on: December 08, 2016, 02:29:44 PM »
Good point as you can see I took the request as the dust shield. The smaller shield around the caliper itself was galvanized
Offline m.b.spuur
« Reply #4 on: December 08, 2016, 09:32:33 PM »
Year its my mistake i was mean caliper shield 😅 Thanks for that
Offline m.b.spuur
« Reply #5 on: December 10, 2016, 06:51:56 PM »
what about the bolts there is holding the bracket, caliper slide too the spindle was they phosphate and oil coating
and was all the bolts too all the suspension and drivetrain also phosphate and oil coating  :)
« Reply #6 on: December 10, 2016, 07:31:06 PM »
Don't know if they were P & O but focus rather on the look rather than how they got there. Believe they were hardened bolts so somewhat darker than steel. Some will used gun bluing and work them from there to get the look while others will phosphate, tumble then oil
Just what I've done successfully
Offline m.b.spuur
« Reply #7 on: December 18, 2016, 07:42:45 AM »
What about the caliper was they Also galvanized On the 1969 😊
« Reply #8 on: December 18, 2016, 02:42:28 PM »
The brake caliper was bare cast iron.
« Reply #9 on: December 18, 2016, 03:11:29 PM »
+1 with the machined surfaces machined after casting
A shot of the caliper shield for others that will read the thread in the future
Offline m.b.spuur
« Reply #10 on: December 24, 2016, 05:10:22 PM »
Now i have Been cleaning my ones and they Are in really good condition 😊
Offline Anghelrestorations
    • Anghel Restorations
« Reply #11 on: December 24, 2016, 10:28:54 PM »
Those are original shields...notice the Ford logo that they have stamped in the top of the shield.
Marcus Anghel
www.anghelrestorations.com
Offline m.b.spuur
« Reply #12 on: December 25, 2016, 01:30:14 PM »
Its a little bite differcult too see Butt the stampel is On it With Ford logo 😊E
« Reply #13 on: December 25, 2016, 01:46:56 PM »
its fomoco  oval   & some calipers were blacked out painted over (69 Shelby) & some were painted silver depending on the wheel option to hide rust showing thru spoke holes.
