Author Topic: October 20th 1964 San Jose Engine bay details please  (Read 3851 times)
Offline 66RavenGTCoupeAgain
« on: December 05, 2016, 03:48:30 AM »
Hi guys,
My wife's SJ convertible is getting re-restored after a PO had already "restored" it back in 85. I'm looking at getting as many of the finer details as correct as possible.
Its a PS and AC car. I would like to see pictures of decal placement and anything else that may be correct for the engine bay detailing that you guys feel should be pointed out. I have all colours/finishes sorted out. (Just got some Corrosion X delivered!) Would also appreciate some help with the correct water pump as ours is aftermarket.
Dan.
« Last Edit: December 05, 2016, 02:39:07 PM by J_Speegle »
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Offline ChrisV289
Re: October 20th 1964 Engine bay details please
« Reply #1 on: December 05, 2016, 10:41:29 AM »
Did you find any traces of holes in your fender apron indicating you had the Eaton power steering pump with the remote reservoir?  if not, you might have had the regular Eaton pump with the special brackets that make it sit lower to clear the compressor.  I believe my car had this as mine was build 10/29/64.  Below is the topic in the wanted ad along with pics of some cars built in October:
http://www.concoursmustang.com/forum/index.php?topic=12755.msg77490#msg77490
2009 V6 Mustang Coupe
Re: October 20th 1964 San Jose Engine bay details please
« Reply #2 on: December 05, 2016, 02:37:51 PM »
Dan we'll need to know what engine the car has
With the Corrosion X I've found that you DON"T want to get it on rubber items so be careful
« Reply #3 on: December 06, 2016, 05:00:54 PM »
How silly of me Jeff,
Its a 289 A code and C4. Did these all have Eaton pumps at this time?
« Reply #4 on: December 06, 2016, 05:21:12 PM »
Will collect some examples and post
May post some here since we already have an example there. At least the service instruction decal is posted there ;)
http://www.concoursmustang.com/forum/index.php?topic=7839.15
Believe so
« Last Edit: December 06, 2016, 05:37:41 PM by J_Speegle »
« Reply #5 on: December 08, 2016, 05:44:02 AM »
Thanks Jeff. Had no idea about that. Thanks to you I didn't learn the hard way!
« Reply #6 on: December 08, 2016, 05:48:29 AM »
I don't think so as all the holes I have are accounted for Chris. Any pics of the fender bracket in situ or holes in the fender? Were all SJ cars built at this time with PS fitted with an Eaton pump?
« Reply #7 on: December 08, 2016, 02:10:18 PM »
Not 100% of the issue but want to error on the side of extreme caution ;)
« Reply #8 on: December 08, 2016, 05:54:23 PM »
Not allot of engine compartment decals when you compare them to other models and years
As for additional details here are a couple
This example suggest that during this time period and plant they were blacking out the top of the steering box
Also they were using dark color sealant between the hood hinges and hood
« Reply #9 on: December 09, 2016, 06:31:34 PM »
It does Jeff. Thanks a lot. The service decal seems to have been applied a lot straighter than my Dec 7 65 NJ car's was. Almost 90 degrees difference!
So is it fair to say that they only installed Eaton pumps during this time in late 64 at SJ?
« Reply #10 on: December 09, 2016, 06:43:46 PM »
IMHO thats what I've seen
« Reply #11 on: December 10, 2016, 08:40:23 PM »
Hmmmm..... Looks like I need an Eaton pun and brackets. Anyone got a spare?
« Reply #12 on: December 10, 2016, 10:26:54 PM »
Looks like time for a request in the Wanted section ;)
Offline mtinkham
  • That'll be easy
« Reply #13 on: December 12, 2016, 02:15:55 PM »
Jeff what was the purpose for sealing between the hood and the hinge...I've never noticed that detail before.
« Reply #14 on: December 12, 2016, 02:50:00 PM »
Honestly have no idea. Have found this and a more brownish sealer used on a number (no pattern) of unrestored first year Mustangs at San Jose. Since its always on both it seems to be intentional just don't see the purpose but maybe there was a worker or engineer that had one
