Author Topic: serial number stamping on 4 speed transmission  (Read 5248 times)
Offline 1966KGT
« on: December 03, 2016, 08:56:30 PM »
is there a serial number stamped on the transmission with vin as on the hipo block? uh , 4 speed heh bx
« Last Edit: December 04, 2016, 05:08:13 PM by J_Speegle »
Re: serial number stamping on transmission
« Reply #1 on: December 03, 2016, 10:03:49 PM »
Yes, normally the VIN would be on the trans also.
Offline 1966KGT
« Reply #2 on: December 03, 2016, 10:49:04 PM »
thank you I will look harder
« Reply #3 on: December 04, 2016, 12:24:12 AM »
Yes, there is supposed to be a VIN on the toploader HP transmissions. However, some, or many, or all (a debate rages) Metuchen built HP Mustangs seem to not have a VIN stamped transmission (engines are included in the debate). If it is stamped, it should be on the bottom of the transmission. This includes HEH BX and HEX T boxes, the latter "T" being found after the change over date. The C4 did not get a VIN stamp.
« Reply #4 on: December 04, 2016, 05:08:02 PM »
Wasn't suppose to be just on K codes but according to records any vehicle with a 4 speed produced after 1963 if I recall correctly. Anti thief/identification purposes
Re: serial number stamping on 4 speed transmission
« Reply #5 on: December 04, 2016, 05:30:12 PM »
Incidental information: I found a replacement T-10 transmission in a San Jose 66 Mustang that had a Metuchen VIN, 6T07A170383. It was a HEK-AD. The stamping was on the adaptor between the main body and tail piece.
« Reply #6 on: December 04, 2016, 06:01:26 PM »
Both the original 66 T10 and the replacement toploader that I got that was date correct for my Metuchen GT did not have a VIN stamp.
Offline sgl66
« Reply #7 on: December 05, 2016, 11:25:03 PM »
I thought that it became legally required in 67 or 68?
I have no VIN on the original block or HEH BX. Maybe it was supposed to happen but Metuchen seems to be where it was often missed.
« Reply #8 on: December 06, 2016, 12:11:10 AM »
1968 was when it was Federally mandated.
« Reply #9 on: December 06, 2016, 05:27:59 AM »
That was for all engines and transmissions. Before that (a Federal programs) most of the car makers marked performance related engines and or transmissions since they felt those were more likely targets and they likely also help identify them for warranty issues if need be since those were likely used a little harder than non-performance. Same books I have that identify the change/start of the 68 all engine/trans programs stated what I wrote earlier
Offline Hipo giddyup
« Reply #10 on: December 06, 2016, 01:21:40 PM »
Nice bonus, if you are missing the correct tranny.   ;)
Offline Texas Swede
« Reply #11 on: December 06, 2016, 02:00:07 PM »
Have always wondered why the Ford number wasn't stamped into the aluminum
T-10's in 65 Shelbys.  The blocks had them but as far as I know, no trans had the
serial number.
Texas Swede
« Reply #12 on: December 06, 2016, 07:32:01 PM »
Yessir!  The toploader is superior to the T10, and because it is a 66, there is no documentation to state that the car did not come with the toploader.
Offline awhtx
« Reply #13 on: December 08, 2016, 12:12:18 AM »
Why did Ford put the inferior transmission in the Mustangs that were destined to become Shelbys?
« Reply #14 on: December 08, 2016, 08:11:43 AM »
Those T-10's were aluminum casings, IIRC, and built up a bit over the normal T10's, or so I've been told.
The T-10's tend to wear with age and pop out of gear; as old trannies, they become inferior to the toploader.  When first installed and used, they were considered one of the stoutest trannies out there until the toploader was developed.
