Author Topic: 67 Horn ( high and low )  (Read 1427 times)
Offline HomerJay
« on: December 02, 2016, 07:01:55 AM »
Hi folks,
looking for a high and a low tone horn for my 67 with AC.
Thanks Homer
Re: 67 Horn ( high and low )
« Reply #1 on: December 02, 2016, 07:59:22 AM »
Tough to find in any condition, "working" condition almost impossible.
If you have the correct originals NOT working, they can be rebuilt. Be sure you know the correct orientation of the rear bracket before buying or restoring any of these. Correct LEFT Side horn will point straight downwards and mount with the AC Condensor, different than a NON-Air Conditioning car. I'm thinking the RIGHT horn is same AC or No AC. Don't know at this moment which is "Hi" or which is "Low" note.
I do not have a good picture handy of the correct ones but will look to see if I can find a picture. (Check back) Here are a couple example shots that are not to clear, maybe a bit of photo shop enhancement can help.
It has been discussed in other threads and pictures have been posted of them too.
NOTE: Both images posted are of RESTORED cars. Other details noticed may NOT be correct for your example. For example, the AMBER Fog Lamps on the Green car, those are not "Concours Correct".
« Last Edit: December 02, 2016, 08:12:34 AM by 67gtasanjose »
Offline tobkob
« Reply #2 on: December 02, 2016, 10:40:20 AM »
If you can't find suitable horns here is another option. Just forget the other application ;)
http://www.zip-corvette.com/63-67-c2/electrical-system/corvette-horn-relays/57-63-horn-repair-refinish-kit.html   or this one
http://www.zip-corvette.com/63-67-c2/electrical-system/corvette-horn-relays/64-75-deluxe-horn-rebuild-kit.html
These fit the horns on a '69 and I think they would be the same as '67...???
« Reply #3 on: December 02, 2016, 11:31:52 AM »
;) Yep, I bought the kits for my 67
Offline HomerJay
« Reply #4 on: December 02, 2016, 12:12:38 PM »
Thanks for your replies. All I have are 2 very cheap Repro horns, so I definitely need other ones.  :(
« Reply #5 on: December 02, 2016, 07:22:30 PM »
Hi folks,
Thanks Homer
PM sent
Offline HomerJay
« Reply #6 on: December 12, 2016, 01:48:44 PM »
Got them, thanks!!!
