Author Topic: 65 Bulbs ?  (Read 1617 times)
65 Bulbs ?
« on: November 29, 2016, 10:42:18 PM »
Correct bulbs for my instrument cluster #1895 ?  These say they a 12 volt 4 watt.  The part number is correct but I don't know about the Watts ?  Thanks,  Brian
Re: 65 Bulbs ?
« Reply #1 on: November 29, 2016, 11:05:48 PM »
The "watts" is power used. It's a function of voltage and current. Wattage can be converted to "lumens" which is the amount of light the bulb will produce. Will the bulb work in your instrument cluster? Yup.
Re: 65 Bulbs ?
« Reply #2 on: November 30, 2016, 12:08:14 PM »
Thank you Jim for the information and confirmation.  I am not fluent in ' automotive electric ' and would not want to over whelm the 12 volt fused system in my car.  The on line conversion tables don't make it easy to convert the assorted lighting terms to actual brightness.  Brian
Offline rodster
Re: 65 Bulbs ?
« Reply #3 on: November 30, 2016, 12:19:47 PM »
If the part number is correct you are good to go.  Specs for a bulb are specific to that part number.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Re: 65 Bulbs ?
« Reply #4 on: November 30, 2016, 04:46:05 PM »
Think "home electric" - a 100W bulb is brighter than a 60W, bulb both of which are rated at 120V. The same approach can be used in a stove's heating element, 1000W is hotter than 500W. The formula is easy - P=IE (or PIE) - Power equals Current (I) times Voltage (E). You can calculate current with this variation - I=P/E. The current draw can tell you wire size. It's not rocket science, but it's a start.
I mentioned "lumens". There is a relationship to power but I'm too lazy to drag out my old engineering books to look it up. The PIE formula was learned in the US Navy back in the late 50's. When I related this formula in a electrical engineering class, the professor was astounded as to how simple it was, and - "How could the Navy teach this". His was an academic world, mine was real.
Offline 5F08KGT
Re: 65 Bulbs ?
« Reply #5 on: November 30, 2016, 10:41:55 PM »
-Ever think of switching to LEDs?
Re: 65 Bulbs ?
« Reply #6 on: December 01, 2016, 12:22:42 AM »
Not very "concourse" are they.
Just for the record, I've not had to replace any of the 1895 bulbs on any of the several 65 and 66 Mustangs I've owned. They are very reliable, but they do burn out. The only miniature bulb I've had to replace in any of my Mustangs was in the one in the radio, an 1891. To do this requires the radio to be disassembled. I have had to replace exterior bulbs.
