Author Topic: 64 1/2 K code Lower Control Arm to Body Hardware  (Read 873 times)
Offline FXguy
    • Early 64 June K Convertible Restoration
« on: November 28, 2016, 11:17:00 PM »
My original lower control arm nuts and bolts were recently plated.  I was putting them back together and noticed that the nuts are jamming when the bolt is about 3/4 the way through the nut.  It's been a long time, so I can't recall for sure if these nuts jammed like this before plating or not.  Anyone know if these things are supposed to jam like this?  They have split/lock washers like on other non K code cars of the same era, so it seems odd that the nuts would be designed to jam AND also have lock washers.
-Scott
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
Re: 64 1/2 K code Lower Control Arm to Body Hardware
« Reply #1 on: November 28, 2016, 11:36:50 PM »
-Scott
No they are not supposed to jam when new.
« Reply #2 on: November 29, 2016, 12:54:24 AM »
Agreed not designed or meant to jamb. Time to check the threads on both the stud and nut. Guess stud by your description
Offline FXguy
« Reply #3 on: November 29, 2016, 12:17:01 PM »
Thanks gentlemen.  I think the plate is a little rough in threads.  Hit the bolt threads with a wire wheel and similarly in the nut and it goes on freely.
-Scott
Scott McMullen
