Author Topic: Coil springs color markings -- 69 San Jose F code  (Read 2207 times)
Offline m.b.spuur
« on: November 27, 2016, 05:51:50 PM »
hello are there some one there know what color there was used at the color markings on the coli springs on a 1969 coupe
Warranty Number: 9R01F160660
Year:   9   1969
Plant:   R   San Jose, CA
Body Series:   01   2 Door Hardtop
Engine:   F   302 2v V8
Unit:   160660   160660
Miscellaneous Vehicle Data
Body:   65A   2 Door Hardtop, Standard Interior
Color:   E   Aztec Aqua
Trim:   2A   Black Vinyl and Black Kiwi Vinyl, Standard Interior
Date:   01D   April 01, 1969
D.S.O:   71   Los Angeles
Axle:   3   2.79:1, Conventional
Trans:   W   C4 Automatic
« Last Edit: November 27, 2016, 11:50:33 PM by J_Speegle »
Re: Coil springs color markings -- 69 San Jose F code
« Reply #1 on: November 27, 2016, 11:50:57 PM »
AC?  PS?
Offline m.b.spuur
« Reply #2 on: November 28, 2016, 09:05:46 AM »
Its a No AC car Butt it have powerstering 😊
« Last Edit: November 28, 2016, 02:32:39 PM by m.b.spuur »
« Reply #3 on: November 28, 2016, 05:33:43 PM »
From buildsheets of similar cars it appears to be
1 Red & 1 Gold. Applied to the loops of the coil spring with spring out of the car sitting upside down (from how it will be installed) or on its side so that runs often look like they travel upward once installed. A semi-dry brush was used for the application. Should be a fair number of examples already posted in other threads  but here are three to illustrate
Offline m.b.spuur
« Reply #4 on: November 28, 2016, 05:49:06 PM »
thank you jeff for that. what kind of paint do you want too use too the markings
« Reply #5 on: November 28, 2016, 06:21:19 PM »
Enamel
If you use the search feature you'll find recommendations or at least suggestions as to brands others have used and are happy with
Offline m.b.spuur
« Reply #6 on: December 30, 2016, 08:36:08 PM »
What about the finish On my springs was they painted Black or was they neutral bare Steel 😊
« Reply #7 on: December 30, 2016, 11:43:34 PM »
Typically San Jose were bare dark very dark heat treated steel.
When you report that yours were painted black I'm guessing that you confirmed that by stripping some of the black off chemically so that the paint bubbled. Best place to determine this is under the paint marks but I've never gotten one that did that.  The heat treated metal will leave small black dust, minute chips in a clean up pan but this is just the chafing of the heat treated steel that remained on the coils IMHO based on the ones I've seen over the years
Offline m.b.spuur
« Reply #8 on: January 03, 2017, 05:09:06 PM »
i well try too give the paint some paint remover and see if the markings is under the paint. butt maybe they have been replacet. like my upper control arms beacuse they was also black,
« Reply #9 on: January 03, 2017, 06:13:31 PM »
............... butt maybe they have been replacet. like my upper control arms beacuse they was also black,
Or simple painted over at some point - think you found a clue    ::)
Offline m.b.spuur
« Reply #10 on: January 09, 2017, 06:52:48 PM »
I was found a little bite red paint On it. Butt its NOT easy too see.
