Author Topic: 67 Reassembly Sequence, Wire Harness  (Read 1086 times)
Offline orgnl70
« on: November 24, 2016, 12:20:47 PM »
I am ready to reinstall the interior wire harness on my 67 . I purchased the car in baskets, so I do not know exactly how it cam apart! My thought is to install the firewall pad first then the Heater/AC unit then the harness. While I am asking, is the fuse box located to the upper right of the gas pedal? Has anyone used the molded rubber firewall insulation kit from Mac's Antique Auto (PN# 44-45422-1)? I know it's not correct but, with what reviews on others available is this the way to go?
Thanks in Advance
Re: 67 Reassembly Sequence, Wire Harness
« Reply #1 on: November 24, 2016, 02:59:06 PM »
I can only answer as to the location of the fuse box: you are correct, it is to the right and above of the gas pedal.
1967 eight barrel
  • Guest
« Reply #2 on: November 25, 2016, 12:54:12 AM »
I'd be glad to get you a picture of the location from my 1967 Shelby under the dash at the block if you need. You can technically start in the engine compartment and the taillamp/trunk first. I did with reassembly. Make sure you get the tail lamp harness in before you start the interior. You have to have access behind the right and left interior quarter trim.
        -Keith
« Reply #3 on: November 26, 2016, 07:23:30 PM »
Yes firewall pad first then you can start from that surface and work forward and rearward from there
« Reply #4 on: November 27, 2016, 12:21:43 AM »
Get a set of Mustang Assembly Manuals for your car's year. By looking at the wiring, body and interior pages side by side, you can get a pretty good idea as to Ford's intent.
