Author Topic: Driveshaft markings -- 69 San Jose F code  (Read 2942 times)
Offline m.b.spuur
Re: Driveshaft markings -- 69 San Jose F code
« Reply #15 on: December 08, 2016, 09:23:26 PM »
Did my driveshaft have markings Like there On the picture 😊
The last picture With the slip yoke i find some red or orange paint On it
« Last Edit: December 08, 2016, 09:28:58 PM by m.b.spuur »
« Reply #16 on: December 08, 2016, 11:10:11 PM »
Are this (this driveline) from you car or another? In the earlier pictures it appears that you have two different types of drivelines one a tube in tube and the other a straight style
Offline m.b.spuur
« Reply #17 on: December 09, 2016, 04:18:10 AM »
The rusty one is from a 1969 250 6 cylinder
And the other one is from 1969 F code San José i trying too restore
 The differentail is from Also from my 1969 F code san José where the markings is complete
« Last Edit: December 09, 2016, 04:22:32 AM by m.b.spuur »
« Reply #18 on: December 09, 2016, 06:55:28 PM »
Well that explains some of the confusion. Colors, copying mark locations from one to the other, yoke colors .... You understand that the strip locations would not likely be the same between the two applications, different colors were used and so on. This is how owners get different marks & details that what was original
To an earlier question. Yes slip yokes would be marked but the color would be specific to the application (driveline & U joint size as well as transmission type) sort of the same thing goes for the driveline yokes. They would have been painted before they were welded to the driveline and even before they were machined (don't forget those details) and the color was dependent on the diameter so since your two drivelines are different in that way you can't use the findings.
Offline m.b.spuur
« Reply #19 on: December 24, 2016, 12:04:16 PM »
Here is some pictures of my driveshaft under restoration 😊
« Last Edit: December 24, 2016, 12:06:23 PM by m.b.spuur »
