Author Topic: Original 66 AM-FM Radio Bracket??  (Read 2629 times)
Offline Morsel
« on: November 07, 2016, 10:58:25 PM »
Does anyone either have a picture or know what the original AM-FM Radio Brackets look like. I realized as I was trying to put it in that it has a different mounting bracket than a standard AM radio. Or if someone has one to sell, I'd be down to buy it, but I've searched online and can't even seem to locate a picture of what one looks like.
Jason
Re: Original 66 AM-FM Radio Bracket??
« Reply #1 on: November 08, 2016, 12:09:32 AM »
There are two assembly drawings of the bracket showing it installed on top of the radio to the dash in the 66 Mustang Electrical Manual.
Offline Morsel
« Reply #2 on: November 08, 2016, 01:16:10 AM »
Thanks for the reply Jim, I saw that in my manual, but I'm actually just on the off chance trying to with find one, or see at least an actual picture of one.
Offline Josep
« Reply #3 on: November 08, 2016, 01:30:25 AM »
Maybe this helps..
Josep
Offline Morsel
« Reply #4 on: November 08, 2016, 02:19:52 AM »
Maybe this helps..
Josep
Thanks for posting Josep, but I believe that's just a standard AM radio bracket, I'm looking for the the AM/FM radio bracket that goes with this radio, see attached... I believe it's shorter in length and should mount on top to the bolt you see in the first picture.
Offline C6ZZGT
« Reply #5 on: November 13, 2016, 02:20:48 AM »
I`d have to look in my car but I don`t think it is any different than the am one/or that the am one does not work.
Brian
66 GT Coupe 6R07A143871 owned since 1983
40+ yr parts man , over 25 with Ford.
Offline Morsel
« Reply #6 on: November 14, 2016, 03:58:29 PM »
It's a different mounting spot, on the AM model it mounts to the back, on the AM/FM it mounts on the top and because of the units size, it I believe has to be smaller I think...
« Reply #7 on: November 14, 2016, 08:15:43 PM »
Maybe you can investigate the indash 8 track mounting bracket It appears to have a upward pointed mounting stud
Offline Morsel
« Reply #8 on: November 14, 2016, 08:34:31 PM »
Yes, we looked at this drawing as well and came to the conclusion it's probably more like this. I may reach out to Brandt because I saw in one of his blogs something about an original AM/FM radio, so maybe he has a picture or something. This would be a good one to have on the forum since no one seems to know.
Jason
Offline Kascus
« Reply #9 on: June 13, 2021, 10:02:23 PM »
Reviving a very old post from the dead. I have the same question. Morsel, did you ever find an original bracket? I have a 66 AM / FM I am about to install but my stock AM bracket won?t work. It looks like I will have to fabricate something while I hunt for the correct one. Problem is, I have no idea what it looks like.
Current:
1968.5 428 CJ Fastback / San Jose 05-15-68
1964.5 289 D Code Coupe / Dearborn 06-05-64
1966 289 C Code Convertible /San Jose 02-11-66
Past:
1965 Shelby SFM5S561
1966 289 FB
1965 289 Coupe
1969 302 Fastback
