Author Topic: 70 MACH1 Engine Bay & Engine Questions  (Read 11312 times)
Offline Blown351stang
« on: November 05, 2016, 09:00:44 AM »
Hi all
My first post and first Mach1 8). I have been thinking of doing a engine bay restoration not concours but a lot closer to the original look. It has been done before at some time in it's life I do not know the cars history.
The car is a 11/69 Dearborn 351 cleveland built car. I have tryed to find photos of some original cars but have not found many and they all seem to look different. So the bay should be semi gloss black with slop gray hood hinge,shock mount? I will put so photos up of what it looks like now.
What air filter housing do they have? like how many holes are in the side of the housing for pipes or are just blocked off.
What oil cap on rocker cover would it have?
All input would be appreciated.
I have some right rocker covers for it.
Is this the right OK stamp for a Dearborn engine?
« Last Edit: May 09, 2018, 09:07:21 AM by Blown351stang »
Re: 70 MACH1 Engine Bay Questions
« Reply #1 on: November 05, 2016, 05:08:03 PM »
First welcome to the site - we hope that it meets you concours related needs for your project or restoration
The car is a 11/69 Dearborn 351 cleveland built car. ...................
No. Hood hinges and springs would have been phosphate and oil as were the front upper shock mounts.
There are a number of unrestored 70 Dearborn threads that will/should help with these generic details for that plant. Don't have to be the exact same engine combination for these details.
Hood latch support and a handful of other parts were a slop gray. Check the FAQs for this section for a list of those parts.
If you would include where your car was delivered to we can narrow down the answer to those questions
Large flat "cookie cutter" style breather with a plastic hose nipple attached
You sure that bottom one is correct?  Formed differently from the other and from others I have pictures of
Dearborn engines were built at the same place as they were for the other two plants so in this case the car assembly plant does not matter in this detail
Three different styles/layouts were used during 70 production from what I have. Most of the time I've found it on the passenger side valve cover and only on a couple on the drivers side. Is this from the original valve covers or ones you've purchased?
« Last Edit: November 05, 2016, 05:13:11 PM by J_Speegle »
« Reply #2 on: November 05, 2016, 07:57:29 PM »
Thanks for the welcome.
The car was delivered to Houston TX.
With the hood hinges and shock mounts being phosphate and oil would they look like this photo?
As for rocker covers no I am not sure if there the right ones for that year I just purchased them as 70's cleveland covers but I do think the light blue one is not right as it has the rocker oil deflector welded in it. The dark blue one would be the passenger side and have a PCV in the spot of the elbow. I thought the dark blue one would be a early cover since the US did not use the cleveland for very long.
« Last Edit: May 09, 2018, 09:09:58 AM by Blown351stang »
« Reply #3 on: November 07, 2016, 11:09:13 AM »
I have a 70 351 c heat shield & tube for the snorkel if you want to correct that.
« Reply #4 on: November 07, 2016, 04:19:30 PM »
Pm sent.
« Reply #5 on: November 07, 2016, 09:56:27 PM »
looks like your snorkel is much more common 71 big opening for 2'' paper tube
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #6 on: November 08, 2016, 01:16:32 PM »
The valve covers with the oil drippers inside are the correct versions for your 70 motor. Later 351Cs did not have them.
« Reply #7 on: November 09, 2016, 04:23:52 AM »
Bugger I will have to keep a look out for another good valve cover.
« Reply #8 on: November 09, 2016, 06:20:45 AM »
check For Sale section
« Reply #9 on: November 10, 2016, 05:39:26 AM »
Had a look but the ones just listed look to be just drives side covers.
« Reply #10 on: November 12, 2016, 06:57:26 AM »
Is this transmission selector arm on the bottom of the steering column normally on manual cars or could it just be a automatic ford column been put in the car?
« Last Edit: October 14, 2017, 07:53:30 AM by Blown351stang »
Offline Vcode
« Last Edit: November 12, 2016, 08:16:54 AM by Vcode »
« Reply #12 on: January 01, 2017, 03:21:49 AM »
Should the grommet above the main wiring in the fire wall have something going through it or should it just be a blank plug?
My engine fan has a big gap between fan & shroud at the top and the bottom of the shroud is broken it looks like the engine sits to low do those engine mounts look right for a cleveland? I want to put a new fan shroud on.
« Last Edit: May 09, 2018, 09:14:13 AM by Blown351stang »
« Reply #13 on: January 01, 2017, 03:59:53 AM »
Believe it depends on what options, accessories, and other things the car was originally equipped with
My engine fan has a big gap between fan & shroud at the top and the bottom of the shroud is broken it looks like the engine sits to low do those engine mounts look right for a Cleveland? I want to put a new fan shroud on.
BTW the stater cable bracket should be attached to the end end of that upper rubber mount (at the block) not down at the bottom
As for the frame mounts I'll see if I have some pictures to share not sure if your going to be able to tell from just looking
« Reply #14 on: January 01, 2017, 06:32:38 AM »
Should the starter cable be between the motor mount & block or exhaust manifold & mount?
