Author Topic: Short vs. Long Style Hood Latch for '67  (Read 1567 times)
Offline drummingrocks
« on: October 29, 2016, 05:01:05 PM »
On my '67 coupe, I've always had trouble being sure the hood is firmly latched.  I literally have to slam it and then pull up on the hood to be sure it's latched.  I looked into adjusting the hood and the catch, but I don't see what I can do that would help.  This is the original hood, original core support, original hood catch.
I looked at reproduction hood latch assemblies, and I noticed that two styles are listed for a '67: a short style for earlier builds, and a long style for later builds.  My car clearly has the short style.  Did Ford change to the longer style because of problems with the hoods latching securely?  I've always hated this issue about my car, and I'd like to fix it permanently.
Thanks--any advice is appreciated.
Re: Short vs. Long Style Hood Latch for '67
« Reply #1 on: October 29, 2016, 07:14:33 PM »
I have only seen the long style originally on 68's . With that said the transition may have happened in very late 67 production . Like many parts that changed it was typically to make them a better more evolved design. To lesser extent some changes were made so as to fit more applications, so less inventory has to be kept. The hood latch change evolved to a better design.
Offline 67350#1242
« Reply #2 on: October 29, 2016, 09:11:31 PM »
If you must slam the hood to latch it, you may need to lower your adjustable hood bumpers.   The latch itself is also adjustable up and down as well as side to side after loosening the 2 bolts holding it to the hood.   My Nov 66 coupe has the short version as well as my Feb 67 Shelby.  Both hoods work flawlessly after fine tuning the bumpers and latch.  You want them making contact when latched, with just a little tension, not so much as to make you slam to latch.
« Last Edit: October 29, 2016, 09:21:47 PM by 67350#1242 »
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #3 on: November 01, 2016, 05:36:24 PM »
Thanks, everyone.  I'll see if I can't make what I have work.
