Author Topic: Ford Jumper Wiring Harnesses  (Read 1103 times)
Online krelboyne
« on: October 25, 2016, 09:14:10 PM »
We often find various wiring harness jumpers or extenders, ones with plugs on both ends with a short section of wiring to connect two different harnesses or electrical component. The above one is for connecting the early 1967 C-4 neutral safety switch to the upgraded wiring harness with the 4 gang plug. It wasn't always used, have seen the individual male / female plugs, plugged directly into the 4 gang plug too.
Midlife, you've probably seen a few in your time too?
Re: Ford Jumper Wiring Harnesses
« Reply #1 on: October 25, 2016, 09:24:15 PM »
Nope: never seen that one!  That's cool.  Probably used during a transition period from separate NSS and BU plugs to a single 4 pin plug.
