Author Topic: 1968 302 4-speed with Thermactor (smog) pump  (Read 2588 times)
Offline Toejamm
« on: October 25, 2016, 02:02:00 PM »
Greetings all,
Does anyone here have a picture of a 68 302 with thermactor and power steering?  I am reassembling a 68 Cougar XR7-G with a 302 and 4-speed.  The thermactor was missing when I got it and I have a replacement but want to be sure of the configuration of the belts and pulleys.  Also, does anyone know where I can get a correct smog belt?
Fran
Present Mustangs:
1967 Branded Edition Mustang Coupe
1967 Indy Pacesetter Coupe
1997 Woodward Dream Cruise Edition GT Conv.
2008 Bullitt  Pre-Production 1PP01 - Media Car - First Bullitt Made
Re: 1968 302 4-speed with Thermactor (smog) pump
« Reply #1 on: October 25, 2016, 06:23:54 PM »
Some pictures that may help with details. Unfortunately no real good unrestored examples :(
Hope these help in some way. As far as belt guess you've already checked Kevin Marti since he is the major supplier of all reproduction belts at the current time. Guess you may have to start looking at the service replacements
Pump bracket
Pump bracket part number - C8OE
Pump adjusting arm
Internal 68 small block system - all San Jose examples
« Reply #2 on: October 25, 2016, 07:52:14 PM »
Any G car with 4 speed is very rare. Which 302 engine? F or J code?
Only 3, F code 302-2V engines came with 4 speed.
A total of 6, J code 302-4V XR7-G's came with 4 speed.
Jeff, any pictures of 1968 302 engines?
The 1968 J code 302-4V engines that I have seen with thermactor smog, had individual smog tubes for each cylinder drilled and tapped into the cylinder heads.
289 smog cylinder heads have a single tube that mounts to the end like in the photos above.
Not sure how the 302-2V 1968 cylinder heads for 302 were handled for smog.
Offline Toejamm
« Reply #3 on: October 26, 2016, 01:47:19 PM »
Jeff,
Those pics (especially the last one) is going to be a big, big help to me.  Thanks
Scott,
26 total 4-speeds, mine is one of the three F-codes.
And I was able to get what is possibly  the correct smog belt from Marti.  We will see when it arrives.
You guys are the best....I have yet to "stump the experts".
Thanks again,
Fran
Present Mustangs:
Offline Scott302
« Reply #4 on: October 26, 2016, 04:33:24 PM »
With or without A/C?  If with A/C is it Factory or Dealer installed?
Regards,
Scott
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
Offline Toejamm
« Reply #5 on: October 26, 2016, 04:59:03 PM »
no A/C
Present Mustangs:
Offline 68NordicCat
« Reply #6 on: October 26, 2016, 11:20:51 PM »
Restoring a 12/67 SJ built 1968 J Code 4-spd Cougar with PS, factory air, and smog. Hope these unrestored pics help.
12/67 SJ Built 68 J code 4-spd Cougar
Offline 68NordicCat
« Reply #7 on: October 26, 2016, 11:51:22 PM »
Have better pics with the engine out of the car but keep getting error messages trying to post here. PM me if you think those would be helpful.
« Reply #8 on: October 27, 2016, 12:23:34 AM »
Not thermactor answer but since I don't see any A/C idler pulleys and you did say you were restoring that you should know you should have the early style A/C pulleys  used in 67 and 68 until sometime approximately in March 68. I am not with my picture file or would show the difference. I will post tomorrow unless someone doesn't post before.
« Reply #9 on: October 27, 2016, 05:14:39 PM »
Will look and see.
Agree I've only seen heads marked 4V (non- smog also) with the external style castings at the exhaust manifold face
Offline Toejamm
« Reply #10 on: October 28, 2016, 11:37:16 AM »
As of now, I think the pics you good people have provided are enough.  I may be back though......
Thank you for your help.
Fran
Present Mustangs:
