Author Topic: 66 A code GT C4ZA-5556-R rear springs  (Read 3939 times)
Offline Turnall
« on: October 21, 2016, 01:06:18 PM »
C4ZA-5556-R  270E5 Springs on my 66 A code GT (Metuchen) with buck tag of K28 - VIN 6T07A135090
Does anyone have any example pictures of these leaf springs and any markings/daubs?
I can see what appears to be white marks on the U-bolts but can't be sure (very faint).
Still working with evaporust...
Allen
« Last Edit: May 22, 2020, 06:13:37 PM by J_Speegle »
Offline Turnall
Re: C4ZA-5556-R
« Reply #1 on: October 21, 2016, 05:03:54 PM »
Though hard to see in the pictures, these appear to be red "daubs" maybe.  Just checking in with what I'm finding and hoping I can get some confirmation.
Thanks again,
Allen
Online CharlesTurner
Re: C4ZA-5556-R
« Reply #2 on: October 21, 2016, 07:54:52 PM »
If you soak those in evapo-rust, the marks will come up.  Does look like red.
Offline ChrisV289
Re: C4ZA-5556-R
« Reply #3 on: October 21, 2016, 10:30:59 PM »
I did this a few months ago, would be best to separate all the leafs and soak each one separately .  I took a 4 inch pvc pipe, cut it in half and capped the ends.  Make sure you use something to counter balance it.  The bigger leafs were a challenge and had to do 1/2 at a time.
2009 V6 Mustang Coupe
Re: C4ZA-5556-R
« Reply #4 on: October 21, 2016, 10:55:50 PM »
Another suggestion is to make a frame with 2x4's, then lay down a couple layers of heavy mil plastic.  Fill with evapo-rust and put the leaves in.
Offline mgmradio
Re: C4ZA-5556-R
« Reply #5 on: October 21, 2016, 11:03:55 PM »
What I usually see on the U bolts is pink paint marks. Here is a picture of a C4ZA-R spring from my 4500 mile Aug 64 Dearborn car.
Formerly the MCA ANHJ 64.5-66!
Offline Turnall
Re: C4ZA-5556-R
« Reply #6 on: October 21, 2016, 11:31:12 PM »
Great suggestion...thanks.
Allen
Re: C4ZA-5556-R
« Reply #7 on: October 22, 2016, 12:00:58 PM »
Think this thru, especially the end of the process. What are you going to do with the liquid when you are done? It's a modern version of "getting the Genie back in the bottle".
Re: C4ZA-5556-R
« Reply #8 on: October 22, 2016, 12:28:43 PM »
I put a similar fixture together and submerged a whole hood on my 67. It took about 20 gallons and this using the hood skin from another junk hood to minimize the amount of liquid needed. Instead of EvapoRust, I bought another more reasonably priced product that also didn't remove paint. It's called Rust911 and sells for about $60 as a CONCENTRATE so it makes about 16 gallons. I also got a bottle of their "Metal Shield 2009" to guard against flash rusting. I swear by this stuff...I've used EvapoRust and it works great but needing 20 gallons becomes cost prohibitive at my budget.
I built my fixture elevated on top of saw horses and simply siphoned off the product when I was finished. Now, getting the 16 gallons of Rust911 back into a one gallon bottle, that wasn't so easy! Maybe a Genie could have done it, but I had to use 16 one-gallon bottles (good thing I save old washer fluid bottles AND I own an auto repair shop  ;) )
« Last Edit: October 22, 2016, 02:28:14 PM by 67gtasanjose »
Re: C4ZA-5556-R
« Reply #9 on: October 22, 2016, 12:39:28 PM »
I built my fixture elevated on top of saw horses and simply siphoned off the product when I was finished. Now, getting the 16 gallons of Rust911 back into a one gallon bottle, that wasn't so easy! Maybe a Genie could have done it, but I had to use 16 one-gallon bottles (good thing I save old washer fluid bottles AND I own an auot repair shop  ;) )
"Auot"? Is that a French car?
And you got the point - think. The Genie won't help one bit.
Offline Turnall
Re: C4ZA-5556-R
« Reply #10 on: October 22, 2016, 01:17:28 PM »
Thanks for the pictures!  I will look closer at the u-bolts.
I haven't built anything for the leafs yet, but will take all into consideration.  I keep my evapo-rust in a 70 quart cooler, so maybe I can get it back in there...
Allen
Re: C4ZA-5556-R
« Reply #11 on: October 22, 2016, 02:26:39 PM »
#dyslexiamoment  ;D
#fixed  ;)
Offline Turnall
Re: C4ZA-5556-R
« Reply #12 on: October 23, 2016, 03:13:33 PM »
Looks like the best I'm going to get on the "daubs".
Allen
Offline 66RavenGTCoupeAgain
Re: 66 A code GT C4ZA-5556-R rear springs
« Reply #13 on: August 01, 2020, 08:47:11 AM »
How are the dates on these deciphered please?
66 Metuchen NJ  GT Coupe
Raven with Deluxe Black Int 289 A Code C4 PS Tinted Windows (Green) Dealer installed Rear Speaker
6T07A1612## Dec 65 Build
65 San Jose CA Convertible Rangoon Red with White Int and Power Top with plastic rear window 289 C Code C4 PS PB AC Fog Lights
5R08C1496## Oct 64 Build
Offline ChrisV289
« Reply #14 on: August 01, 2020, 12:09:07 PM »
The dates should be in a number format. Like 150 is the 150th day of the year or May 30th
