Author Topic: 289 intake bolt washers  (Read 827 times)
Offline 7R02A
« on: October 18, 2016, 05:48:50 PM »
All, I am curious what is the correct washers to use on a '67 289 intake manifold bolt.   My originals appear to have an aluminum washer.  NPD sells a rubber coated washer.  Which is correct?  Car details in signature.
1967 Fastback, A code, automatic transmission, Deluxe interior, AC, PS, P disc brakes, tilt, consoles, exterior group, fold down, DSO 71.
San Jose build, Actual build: Dec 17, 66.
Offline Scott302
Re: 289 intake bolt washers
« Reply #1 on: October 18, 2016, 07:02:18 PM »
John,
The original washers were "rubber" coated aluminum to seal the few bolt holes that are open to the water passages.  The coating on yours has worn off over time and use.  It doesn't take much to separate the rubber and I doubt they were ever intended to be used more than once.
The washers we have are US-made by the original supplier to Ford.
Regards,
Scott
Scott Halseth
Ford Product Manager
National Parts Depot
MCA#01776
Offline 7R02A
« Reply #2 on: October 18, 2016, 07:06:00 PM »
Thank you Scott.  That's what I needed to know.
« Reply #3 on: October 18, 2016, 08:16:55 PM »
And the washers are Ford part number - 379257-S100.
