Author Topic: Rally Pac Clock Part  (Read 1024 times)
Offline suskeenwiske
  • 214-347-3628
« on: October 18, 2016, 03:47:23 AM »
I'm looking for a good Rally Pac Oscillator / Balance Wheel. One end of the one on my clock has partially broken off which is causing it to wobble. If anyone has one or knows of a source, please let me know.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Re: Rally Pac Clock Part
« Reply #1 on: October 19, 2016, 09:03:17 AM »
Ray I have several clock movements removed to replace with quarts movements out of 67-68 clocks. They look to be the same as one in you picture. Let me know if you want to try one.
Marty
« Reply #2 on: October 19, 2016, 01:40:21 PM »
I got a mix of 65-66 and 67-68 clocks a couple of years back from a friend and I think they were not interchangeable, at least not easily. The MPC shows a part number for 65-66 (C5ZZ-15000-B) but none for 67 on. It may be the externals, the adjustment knob for one, but I don't know. What I did was burnish the contacts clean and sent them back to be sold. Bad contacts is the main reason for clock failure, although one 67-68 main spring was bad (sound familiar?).
« Reply #3 on: October 19, 2016, 09:13:42 PM »
No part numbers. Here is what it looks like
  • 214-347-3628
« Reply #4 on: October 20, 2016, 01:52:08 PM »
You're correct...they do appear to be the same and would like to confirm by comparing it to mine. Would you IM me with the details to get one from you?
Ray
Ray
1965 Dearborn Coupe
Est. Build 23A
