Author Topic: 1966 fastback trunk lid fit & weatherstrip  (Read 5476 times)
Offline Brant
Re: 1966 fastback trunk lid fit
« Reply #15 on: October 18, 2016, 09:33:03 AM »
There may be other reproductions with the correct u-shaped design, but the Daniel Carpenter brand is very accurate and works perfectly. As others mentioned, for years the Ford "replacement" weatherstripping was a different design than the original assembly line part. I think this has led to confusion over the years, as I have seen quite a few nice cars at shows with the incorrect NOS weatherstripping.
Here is the correct version. We just installed one with perfect results.
Offline DKutz
« Reply #16 on: October 18, 2016, 03:35:46 PM »
opening in the "U" goes facing inside right?
If I use this will my fastback turn into a shelby?
« Reply #17 on: October 18, 2016, 04:00:11 PM »
Yes, U goes to inside and the shorter lip is glued to the deck lid.
Offline DKutz
Re: 1966 fastback trunk lid fit & weatherstrip
« Reply #18 on: October 18, 2016, 05:41:06 PM »
OK so I found my order for the trunk weatherstrip.  I ordered from CJ it is a Scott Drake Part.  Is this a huge difference from NPD and DC part?  I did at least get the right profile.
D
« Reply #19 on: October 18, 2016, 06:05:07 PM »
It is so frustrating to read about the many occurrences of inferior quality parts that are purchased through CJ because I read this time and time again on this forum. I will only buy from ether Virginia Mustang or NPD . Even though they are not infallible the chances of getting a quality part are much higher . I can only assume that the main motivation to buy from CJ is price because nothing else seems to be obvious. I don't even see the price being pennies difference overall. I can't imagine that there is that much difference to justify the risk . I believe CJ is a reputable retailer but their choices of inventory is not always in keeping with the spirit of this forum . You only have to get one unusable part to nullify the savings on the potential numerous purchases before you are back even. If you get a less then acceptable part you only have yourself to blame for your wasted time and money. Others may have a different opinion. I am getting down off of my soap box now. :)
« Reply #20 on: October 18, 2016, 06:09:56 PM »
D
DC weatherstrip although not as good as original Ford typically fits better because it is closer to being as spongy as Ford weatherstrip . Hard or harder weatherstrip makes fitting a bad experience IMO.
Offline DKutz
« Reply #21 on: October 18, 2016, 06:23:04 PM »
so how does SD compare to DC??
« Reply #22 on: October 18, 2016, 07:48:58 PM »
SD typically is denser/harder  foam.
« Reply #23 on: October 18, 2016, 08:19:24 PM »
I will only buy from ether Virginia Mustang or NPD.
I agree. Add AMK to the list. All three will work with you and stand behind their products.
« Reply #24 on: October 18, 2016, 08:48:19 PM »
+1, these are my main go-to vendors when needed.
Offline sgl66
« Reply #25 on: October 19, 2016, 12:17:05 AM »
Interesting info regarding the difference in weatherstripping...I will definitely take a look at that.  Guess the way to tell would be to remove it and see how the fit is without it.  I would like to think this amount of misalignment would not have been acceptable...even in 1966, on a relatively inexpensive vehicle.
I have the same issue. Interested to hear if removing the weatherstripping solves the problem.
I replaced mine 20+ years ago and at the tallest point it is a little over 1/2 inch. I have a spare trunk lid with the original weatherstripping I need to dig out and see how that compares. I also noticed on the right side that the weatherstripping is installed maybe too far from the edge causing it to land on the ridge at a higher point on the weatherstripping than it should. The right corner appears to barely touch and the center of the right side seems to be where most of the contact is. The other thing I noticed is the factory seemed to grind the ridge down toward the corner where the sheetmetal overlaps but only on the right side. I don't know if there would be enough metal to cause misalignment but who knows? I also found 1 picture from 1980 before any body work was done and the corner was off then also
+2 on VA Mustang
« Last Edit: October 28, 2016, 01:34:47 PM by sglbbs »
Offline sgl66
« Reply #26 on: October 28, 2016, 01:36:50 PM »
I measured an original today on an extra lid and it's .4 inches at the highest point. The repo I have is .57 at the same point.
