Attached are a couple of pics of my AC compressor clutch and pulley, which I do not believe are correct. Can someone tell me if they are correct, and if so, where to have them plate. Otherwise, where is the best source for correct ones. I have also attached a pic of the side of the compressor that the clutch/pulley attaches. Thanks. Rick
San Jose, Bob. Sept. build. Thanks.
This is a double R-code 428 car built mid-October 69 (per Marti) in San Jose. However, it is not a factory AC car, but I am trying to make it correct. Compressor is dated March 69. All lines are original and marked with part numbers. A dealer owned the car and added AC obviously from an original AC car. The dash components are all dated 1969. I have all the correct 1970 idler pulleys and brackets.The AC clutches that I have pics of are mounted with 4 small bolts to the compressor. This one just mounts to the keyed compressor shaft and the center bolt. It is obviously painted black. Others I have pics of are plated. Thanks for the help. Rick
