Author Topic: 68 Reverse Lockout  (Read 1308 times)
Offline 68NordicCat
68 Reverse Lockout
« on: October 06, 2016, 12:54:08 PM »
Quick question - is there a bushing (or anything) between the reverse lock-out flange and the shifter? On reassembly it seems to have a lot of play and I'm concerned about rattle (see pic - round flange type lockout - not T).
12/67 SJ built '68 J code Cougar
Thanks.
Dan
12/67 SJ Built 68 J code 4-spd Cougar
Re: 68 Reverse Lockout
« Reply #1 on: October 06, 2016, 02:27:25 PM »
Yes, there should be a plastic sleeve there like the 65-7 shift handle.
« Reply #2 on: October 06, 2016, 03:06:30 PM »
Bill Healey replaced the insulator grommet on my 66.  To do so, you have to break the solder joint of the lockout cable, but it can only be silver-soldered on again.  That's beyond my skill set.
Offline 68NordicCat
« Reply #3 on: October 06, 2016, 05:47:24 PM »
I think the difference between the earlier models and 68 (not sure when it changed) is the circular flange (held in place with a roll pin that passes through a hole in both the flange and also a piece at the top of the cable) vs the t-shaped lockout which I understand was actually fixed/soldered to the cable. I am able to disassemble the lockout flange and cable without dealing with a soldered joint.
« Reply #4 on: October 06, 2016, 10:21:24 PM »
Right, you don't have to do anything with the solder on the '68 handle.
Offline 68NordicCat
« Reply #5 on: October 06, 2016, 10:55:57 PM »
Any idea on a source for the plastic sleeve? Or a substitute material?
« Reply #6 on: October 07, 2016, 12:06:26 AM »
Might check with Bill Heeley, in Maryland.  Google search should find him.  He specializes in shifters.
1967 eight barrel
  • Guest
« Reply #7 on: October 07, 2016, 03:25:13 AM »
I posted Bill's information last week. He's on Ebay as well. Just look up Ford top loader shifters. He comes up. If you have issues, PM me. I'll give you his phone number and address. He can replate as well as repair factory shifters, even the cable that operates the lock-out mechanism.
