Author Topic: 68 brake booster vacuum !?  (Read 1354 times)
Offline mhubert89
« on: September 27, 2016, 12:39:57 AM »
Hi ,
When i buy my car , this vacuum fitting was on my intake .. Its is a original one for my car or what suppose to look the fitting that go on the rear of the intake for the vacuum ?
Mustang Fastback 1968
289, 4 speed
Re: 68 brake booster vacuum !?
« Reply #1 on: September 27, 2016, 01:31:04 AM »
Hi ,
Looks like the right piece difficult to say for sure with one angle only
The big plug is removed and replaced with a steel formed tube and a fitting to attach it to the vacuum block like other years. The rubber flex line that runs to the PB booster is attached to the end of the steel tube/line
Picture shows a rear vacuum block for a non-PS car the way its configured at the moment
This block screws into another odd shaped vacuum attachment that attaches to the intake on a 68 C & J code
« Last Edit: September 27, 2016, 01:38:45 AM by J_Speegle »
« Reply #2 on: September 27, 2016, 09:38:13 AM »
I stole this from another thread. It shows the complete assembly.
Offline mhubert89
« Reply #3 on: September 27, 2016, 11:09:42 AM »
Oki perfect . So if i put PB on my car this block its not good and need to buy one for a PB !!?
289, 4 speed
« Reply #4 on: September 27, 2016, 04:49:50 PM »
The one you have in your picture has four small capped ports, one medium port and one threaded hole that is plugged. Replace the plug with a power brake tube fitting and you can hook up the vacuum required there. The tube fitting looks like the one Marty has in his picture.
« Reply #5 on: September 27, 2016, 09:46:44 PM »
+1 At least that is what it looks like from the picture you posted. Just need the "spark plug" looking fitting to attach it to
Fitting arrangement for a non- PS set up
With the plug removed - point of attachment for the PB tube and fitting
Offline mhubert89
« Reply #6 on: October 06, 2016, 09:10:52 AM »
Oki thanks for the picture
289, 4 speed
