Author Topic: Steering column cover "adjustment" (horn fix)  (Read 1060 times)
Offline 3310
« on: September 21, 2016, 07:44:38 PM »
Horn is not working after I replaced my aftermarket wheel with a stock unit.  It appears that one of the 2 horn contacts in the column is not touching the steering wheel,  hence horn not working.
To fix this,  as I read elsewhere,  the steering column (cover) apparently can be moved in and out,  independent of the steering shaft inside.  Thus you should be able to pull the column towards you slightly,  resulting the horn contacts coming closer to the steering wheel contacts.
I've loosened, but my steering column cover is not moving.  Anyone already experienced with this?
1968 390 GT
Re: Steering column cover "adjustment" (horn fix)
« Reply #1 on: September 21, 2016, 07:52:39 PM »
You will have a certain amount of resistance from the rubber insulator on the top of gear box and the one going through the cowl.
Offline 3310
« Reply #2 on: September 22, 2016, 08:00:26 PM »
Well I have it loose enough to be able to rotate the column, but I CANNOT pull it up at all.  Can I get some more input on this ?
1968 390 GT
1967 eight barrel
  • Guest
« Reply #3 on: September 22, 2016, 09:24:44 PM »
Long shaft, or with a rag joint?( Two piece)  Then we can discuss the fix.
« Reply #4 on: September 22, 2016, 10:02:45 PM »
Good to see you back Keith...hope you are doing OK
1967 eight barrel
  • Guest
« Reply #5 on: September 23, 2016, 12:51:12 AM »
Rich, I'm this side of terra Firma. Good start. Just flat worn out and exhausted. Thank you.
        -Keith
