Author Topic: 1965 / 1966 V8 Radiators - Including Solidered Tags  (Read 18487 times)
Offline macdude67
Re: 1965 / 1966 Radiators - Including Soldered Tags
« Reply #30 on: May 03, 2017, 06:20:39 PM »
Autolite,
Don't want to hijack your thread, but need groups opinion about this radiator. I uncovered it with the rest of my Hi Po parts. Has a couple of tags that I believe are radiator repair shop tags. They used them years ago to id customers radiators. Also wantwant some feed back on weather this radiator would be appropriate for an April 65 Hi Po.
Strange I have a radiator also Stamped 4FG
Offline Texas Swede
« Reply #31 on: May 03, 2017, 06:54:36 PM »
I have always thought, W-MO stood for Whittier-Modine and not Western-Modine.
Never get too old to learn something new. Great information, thanks.
Texas Swede
Offline Skyway65
  • Gold Level Subscriber
« Reply #32 on: May 09, 2017, 10:33:39 PM »
Just to add another example to the mix, here are the numbers from a factory original Dearborn, January '65, 6 cyl/auto, no air, radiator.
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline Skyway65
« Reply #33 on: May 10, 2017, 06:55:26 AM »
Is "DEP" stamped on the strap/rail? Normally its before the "C4ZE" and I don't see it visible in those photos.
I'll double check that for you.
Gary Schweitzer
MCA #00181
Traverse City, MI
« Reply #34 on: May 10, 2017, 12:11:30 PM »
Agree, something fishy with that one.
Re: 1964-1/2 , 1965 , 1966 Radiators - Including Soldered Tags
« Reply #35 on: December 03, 2017, 07:07:51 PM »
G2 lid dated 7-64 example.
That  7-64 example appears to be one where the "G" was added.
« Reply #36 on: December 03, 2017, 07:20:45 PM »
Or one that was changed/relabeled from a G
Offline rocket
« Reply #37 on: January 25, 2018, 08:46:24 PM »
Great info. I have a 64.5 K Code, Convertible, 76A S 89 21G 13 9 5
Assembly Date of my car is July 21, 1964
DEP C4ZE 8005 –G14DD
Tag attached to front – 4DC 14 = 64, April, 3rd week.
Didn't know my radiator (HIPO) was different from all the other V8s.
G application code = 1965 / 1966 V8 289 Application Identification:
C4ZE-
G = manual transmission - Extra Cooling (C-code w/AC, A-code w/AC, K-code, GT350)
Thanks.
Is DEP an acronym for Dearborn Engine Plant or Detroit Engineering Products?
Offline rodster
« Reply #38 on: January 26, 2018, 12:17:17 AM »
Is this little 'loop' something added during the recore?
I have the same thing on my 65 M1 radiator.
Great info by the way!
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline GT500KR
  • Charlie Ping
« Reply #39 on: January 30, 2018, 03:30:28 AM »
Those raised "loops" are used to clamp and tighten the straps while soldering during the rebuild, yes. But they are there from day one, as the original build used them also.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 Jalapeño Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
Offline eliminator
« Reply #40 on: May 22, 2018, 09:43:16 PM »
Am new here, 76 and internet challenged but finally found this site and have a little info you may be able to use. Bought a 64 1/2 convert from the original owner (who passed away) a couple years back and just getting around to getting it running/driving. Radiator was replaced for some reason and car came with the original radiator in the replacement box. Nothing wrong with it - looks perfect but the numbers don't exactly compute with the radiator listings on this site. They are: DEPC4ZE 8005 A 1-4EA. It is listed on this site as being for a 260 M/T. This car is a one owner California unmodified original with the original window sticker - was used only as a daily driver. However it has the 289V8. A possible explanation: WIndow sticker states $2703.00 for a Mustang convertible V8 plus a few options like the 4 speed for $188.00 and at the bottom of the options it lists $65.70 for a 289 4V V8 engine. So evidently the radiator was used for both the 260 and 289. You may already know of this but if not it might be helpful in your listing of radiators. And I may be wrong about this assumption - would be the first time this year......Cheers.....Richard
« Reply #41 on: May 22, 2018, 10:47:08 PM »
Welcome Richard
You might post more information about the car your describing - when and where it was built as these factors are often very important in discussions.  Thanks for including the date when the radiator was made also ;) Helps in discussions like this
Since your going to be asked this  over and over you might consider  adding it to your signature (you'll be able to make that addition in your profile / button above between HELP and ADMIN)
Hope you find this site useful and helpful in your related endeavours
Offline eliminator
« Reply #42 on: May 23, 2018, 09:31:40 AM »
OK - thanks - don't know what you mean about adding "it" to my "signature" (I still use cursive) but here is all the info on the car: 1964 1/2 Mustang convertible, color J Rangoon red, Trim 86 black, Date 26E may 26, 1964, DSO 24 Jacksonville, axle 1 3:00 :1, trans 5 - 4 speed manual, aluminum tag on intake manifold - 289 - 65 - 4E - 550C, power top, 4 speed trans, 650X13 tires, rocker panel mouldings, AM radio, padded visors, 289 V8 - that's it. Guy was a little frugal with options. Assembled in Dearborn Michigan, serial number 5FO8D 146830, sent to Hailey Ford in Winter Haven, Florida - bought there and driven back to California. Any other info wanted just let me know, as the car is untouched original and is a good reference model. Richard
« Reply #43 on: May 23, 2018, 11:09:44 AM »
OK - thanks - don't know what you mean about adding "it" to my "signature" (I still use cursive)...
It is in an area under "PROFILE" header above the message board area (Home   Help   Search   PROFILE    My Messages   Calendar   ...)
You can add this information in and it will post EVERYTIME you ask or answer any questions.
Offline GlennG
« Reply #44 on: May 25, 2018, 07:20:14 PM »
I have a question regarding this radiator.  After reading the posted  radiator data, my radiator appears to be too early for 1964 1/2....maybe it's not a Mustang radiator at all... I have had it for many years and my feeble brain thinks I pulled it off a Mustang many years ago.  But the stamped markings on the side mounting says C3DE BE1.  On the top of the radiator is stamped FoMoCo, and there is a soldered tag on the top side of the tank that reads 8MB 7.  Maybe from a Falcon?
So what's the verdict on my mysterious radiator?
'65 Mustang Coupe - Restoration after I get Hertz running
'66 Hertz -In process of mechanical and body resto; has not run since the 1970's- a real rat rod
