Author Topic: 1965 / 1966 V8 Radiators - Including Solidered Tags  (Read 18484 times)
Re: 1965 / 1966 Radiators - Including Soldered Tags
« Reply #15 on: September 19, 2016, 05:26:11 PM »
Does your G1 have 12 fins per inch? I found this chart which I believe explains the difference between G1 and Y1 radiators.
What year is that chart from? Noticed the 390 Fairlane and had to ask
Offline sgl66
« Reply #16 on: September 19, 2016, 05:54:47 PM »
Found it here, 66 Shop Manual: https://www.scribd.com/user/3802918/api-3802918
Section 11 cooling system: https://www.scribd.com/document/7015750/Group-11-Cooling-System
I have a beat up 66 hard copy of a manual that appears to identical but it doesn't have that radiator chart but instead has every fan belt, radiator cap and thermostat application.
« Reply #17 on: September 19, 2016, 05:58:50 PM »
Found it here, 66 Shop Manual: .............
Section 11 cooling system:..........
Offline larryharvey
« Reply #18 on: September 20, 2016, 01:20:20 PM »
Yes it does have 12 fins per inch.
Sorry for the delayed response.
Larry
65 April 13th Dearborn K code GT
Offline ChrisV289
« Reply #19 on: October 03, 2016, 09:05:24 PM »
Saw this one over the weekend if anyone is keeping track
2009 V6 Mustang Coupe
Offline 1966KGT
« Reply #20 on: January 14, 2017, 05:00:15 PM »
So I'm TOTALLY confused now, what am I looking for to be correct for my 11-08-65 SAN JOSE built Hipo, manual trans. WM O on tank with soldered tag? sept , oct or nov date?
« Last Edit: January 15, 2017, 11:13:15 AM by 1966KGT »
Offline 1966KGT
« Reply #21 on: January 16, 2017, 08:13:51 AM »
thanks JD
« Reply #22 on: January 16, 2017, 02:43:41 PM »
Looking at other K codes built around the same time as your I would choose the Oct dated if you had a choice ;)
Offline 1966KGT
« Reply #23 on: January 16, 2017, 03:11:48 PM »
Thank you
Offline ChrisV289
« Reply #24 on: February 24, 2017, 10:27:23 PM »
My friend who has a shop found a C4ZE S2 radiator in his shop. Had a 5-64 date code and no holes for transmission cooling lines
Offline 1966KGT
« Reply #25 on: February 24, 2017, 10:54:17 PM »
i really appreciate the response but being I, am a ways from having the mustang back running I actually hope I can get an oct/65 g2, thank you.
« Reply #26 on: March 12, 2017, 06:26:46 PM »
Here is my big question on 6-cylinder radiators...
Has anyone verified a factory DEP or NON W-MO (Western Modine) radiator in a 1964-1/2 - 1965 production 6-Cylinder?
Not so much verified since I'm looking at pictures and can't go take another look. But I do have a group of unrestored 65 Dearborn 6 cylinders all with the same top tank, Flat space with nothing in it and the square (sort of) corner straps
« Last Edit: March 12, 2017, 06:27:39 PM by carlite65 »
Offline ilhusker
« Reply #27 on: April 30, 2017, 11:35:02 PM »
Here is some 6 cyl., 64-1/2 info.  Dad picked this up on April 18,1964 in Bristow, OK
Tom
5F07U110879
Wimbleton White/Palomino
3 Spd M/T - April 9, 1964
Axle 3.50:1  13 inch/4 bolt wheels
3F05H104931
1973 Mach 1 Wimbledon White/Black
351 C FMX Auto
Offline ilhusker
« Reply #28 on: May 01, 2017, 12:24:29 AM »
I will add that the car was in a front accident in 1967 or so, but I don't believe the radiator was damaged.  I think that's the original...as best as I can tell.
Tom
5F07U110879
3F05H104931
351 C FMX Auto
Offline ilhusker
« Reply #29 on: May 01, 2017, 01:05:48 AM »
A few more clarifications in photos.  No A/C
Tom
5F07U110879
3F05H104931
351 C FMX Auto
