Author Topic: Use of original hoses  (Read 2785 times)
« on: September 07, 2016, 07:06:03 PM »
I have a reasonably nice set of C6OA-3A714-A short power steering hoses, see pics.  Is it a dumb idea, speaking bluntly, to use these on an occasional driver?  If not are they of value to a trailered or Tbred?  The last pic is the weakest link.  I can pressure test them if there is doubt.  Thanks
Re: Use of original hoses
« Reply #1 on: September 07, 2016, 07:10:20 PM »
I would not use those, a power steering leak (picture spraying everywhere) isn't worth the time to clean that mess up. I've bought some new ones, NOS with the right crimping & numbers.
« Reply #2 on: September 07, 2016, 10:21:26 PM »
A crack in the 3rd picture hose disqualifies it from the reasonably nice category. The repros are done like later 68/69 fine ribbed hoses.
« Reply #3 on: September 08, 2016, 07:38:19 AM »
Thanks for the replies!
« Reply #4 on: September 08, 2016, 01:19:28 PM »
anybody know when the c60a# started showing up on the 2 short P/S  hoses as they are dated you know?
« Reply #5 on: September 08, 2016, 04:43:41 PM »
Ed, while I don't have the answer to the "when" question, I can provide some data.  I have 7 sets of original (based on single crimp and hose characteristics) hoses.  The one from my Dec 66 build included.  Mine and 5 other pairs have no part number stamp.  Each hose does have CYL on one end, and were attached to the piston CYLinder end.  The remaining set has the part number on only one of the two hoses, and carries a date of 0718.
Your questions and my observations lead me to believe that "early" had no date code, "late" did, and we should try to figure out an approximate date for the change.    Again my Dec 20, 1966 did not have the date, the hoses appear to be original, but I can't prove that.  However, if they were originally date coded one could expect that service replacements would be as well
