Author Topic: Help with definitive Shaker ID  (Read 6307 times)
Re: Help with definitive Shaker ID
« Reply #30 on: October 09, 2020, 07:34:59 AM »
Thanks Jeff.  Based on pictures there, it appears that the one that I posted pictures of is for a 351.  There is not enough for me to determine if Windsor or Cleveland, so I'll need more pictures or dimensions from known examples to narrow it down further.
Offline JohnB
  • 0F03R120303
« Reply #31 on: October 09, 2020, 01:30:26 PM »
Some info here: http://www.boss302.com/shaker.htm
« Reply #32 on: October 09, 2020, 05:16:03 PM »
Yes the odd (not something I've seen on Mustang ones I've owned) thick spacer or riser I believe will be one of the big determiner of its origin. Given the height of the top of the carb the smaller motor makes sense - ie Windsor
If not for the studs I would look towards the ram air air cleaners for other applications but those limit the application.
Not likely but could always be something someone made - which would make identification impossible - but as said that is not likely
