Bob, the engine was cold after replacing the Vacuume Advance Control Valve. I left the cap off and warmed up the engine to allow any trapped air out and to verify the t-stat was working as well as the water pump. The block was standard bore before the rebuild and I was not notified that any additional boring was required over the standard amount that would have been required. I spoke with a close friend who is heavy into old Mopars and runs a few auto repair shops and he said the volcano was simply an air pocket that let go when I shut down the motor. As to the radiator I verified it this morning that it is a 3 row core. From the appearance of the fins on the core it appears (but i am not 100% certain) that it may have been re-cored but my memory isn't what it used to be. It would have occurred about 6 years ago. So results from today's tests are below with some odd results. By the way I tried to restart it about 2 hours later last night to try some more tests and she would not re-fire. Even tried starter fluid and nothing. Nothing else was touched in anticipation of further testing today
Yesterday my base timing was 10* BTC with the vacuum advance hose removed and plugged and engine idled at approx 750 rpm.
This morning after a 5 min warm-up the base timing is 2* and my idle is about 750 rpm. Wait another 5 min and still stuck at 2. We increase rpm to 2000 and mechanical advance is 25 degrees which seems a bit high (14-17 per spec). Plug the vacuum line into advance and idle increases to 1200 rpm and vacuum advance reads 40 degrees. The 40 is within spec but why did the rpm climb?
So we adjust the distributor back to 10* and measure mechanical advance by raising rpm to 2000 and now we are at 25 degrees. That's a big jump so we now plug the vacuum line into advance and engine is screaming at 1700 rpm. Raise it a touch to 2000 rpm and vacuum advance reading is 50 degrees.
During the entire warm up process i am using an infrared gun (ok a cheapie harbor freight I admit but better than nothing) to get some temps of the intake manifold flat spot right below the carb on the drivers side. After 1 min 110*, 3 min 133*, 4 min 170*, 5 min 185*, 7 min 219*, 12 min 230* and finally after 21 min 270*. Turn engine off and 275 degrees. So I shoot the top of the radiator, RH side of tank at upper hose 212, middle at cap 188 and LH side 209 degrees. So no big surprise that engine doesn't want to re-fire if intake is 270 degrees. Can anyone test their FE for intake manifold temps? It was about 80 degrees with 68% humidity. Today's ethanol blend fuels have a boiling point of 140 I am told.
I'm at a loss.
