Author Topic: Sway Bar Size  (Read 2469 times)
Offline orgnl70
Sway Bar Size
« on: August 22, 2016, 09:18:24 PM »
1967 N.J. Big Block GTA. What is the correct size (Dia.) sway bar for this car as it came from the factory?
Re: Sway Bar Size
« Reply #1 on: August 22, 2016, 10:08:17 PM »
Does it have anything special like competition handling package?
Offline orgnl70
Re: Sway Bar Size
« Reply #2 on: August 22, 2016, 10:25:01 PM »
Nothing special as far as suspension.
Offline BKnapp
Re: Sway Bar Size
« Reply #3 on: January 02, 2018, 10:22:30 AM »
My Marti Report calls out Heavy Duty Suspension, which I think is the 7/8" sway bar? - I do not know if that is different than the standard 390 sway bar. I am in the process of replacing the bushings and brackets. Was the standard bracket used for the Heavy Duty Suspension and 7/8" sway bar? I know the Competition Handling Package came with a slightly larger sway bar and bracket.
Re: Sway Bar Size
« Reply #4 on: January 02, 2018, 11:16:27 AM »
Offline BKnapp
Re: Sway Bar Size
« Reply #5 on: January 02, 2018, 12:23:15 PM »
Thanks Charles... I had read that thread a couple of times and could not determine the differences/similarities between “Competition Handling Package” and “Heavy Duty Suspension”. My Marti Report indicates “Heavy Duty Suspension”. Was this the same suspension as the CHP, with the difference being the CHP including a variety of other upgrades such as tires, hub caps, etc?
Re: Sway Bar Size
« Reply #6 on: January 02, 2018, 02:50:03 PM »
Believe that Heavy Duty Suspension in 67 was the same as GT Suspension not the Comp Handling Package
Re: Sway Bar Size
« Reply #7 on: January 02, 2018, 02:55:44 PM »
My GTA deluxe Marti report does not list any suspension option, but we know that the GT equipment group option included an upgraded suspension.  I have quite a few options so could that have been left off?  The sway bar (original) is 7/8”
Re: Sway Bar Size
« Reply #8 on: January 02, 2018, 04:00:27 PM »
My GTA deluxe Marti report does not list any suspension option, but we know that the GT equipment group option included an upgraded suspension.  ...  The sway bar (original) is 7/8”
CORRECT! This is also true of the 390 GT's (w/o comp susp.)
Offline BKnapp
Re: Sway Bar Size
« Reply #9 on: January 02, 2018, 10:56:51 PM »
Thanks guys... mine measures 7/8”. so I will assume it is correct. It’s a non GT, but has Heavy Duty Suspension. I am afraid to ask about the end links. Would this have come with the standard 1.5” spacer or the longer 2.25” spacer? I have ready a lot on the CHP, but couldn’t find much on the 390 Heavy Duty Suspension.
Thanks again!
Re: Sway Bar Size
« Reply #10 on: January 03, 2018, 06:31:17 AM »
Since you don't have the GT equipment group option, it makes sense that the Marti report would show the optional heavy duty suspension.   Unless there is evidence otherwise, I would conclude that the heavy duty suspension is the same as what is included with the GT option.
The 67 MPC calls for C0DZ-5A486-B which includes the KD-5490-A spacer, for all models.  There is no length listed.  I can measure mine tonight if someone doesn't get to it first.
Offline BKnapp
Re: Sway Bar Size
« Reply #11 on: January 03, 2018, 08:08:24 AM »
Thanks, John. The KD-5490-A is the smaller 1.5” spacer, according to AMK. Your help is greatly appreciated.
Re: Sway Bar Size
« Reply #12 on: January 03, 2018, 04:53:25 PM »
+1  Its the same thing without all the fancy exterior do-dad's :)   Before the GT package was available in 65 the heavy duty suspension was the only choice for those that wanted something a little more sporty in the handling department
