Author Topic: Starter  (Read 3471 times)
Offline sparky65
Starter
« on: June 28, 2010, 09:37:31 PM »
Well one of the mounting tabs on my starter is broken.  It could very well be an original but I don't think its worth much with the tab broken.  How are the reproduction versions.  Is it possible or worth it to salvage anything from my original to put on the reproduction?
Steve
2009 Black GT Coupe
Re: Starter
« Reply #1 on: June 29, 2010, 12:54:03 AM »
You might try your local auto parts store.  They might have some OEM rebuilt ones for sale.  Sometimes if you're real nice, they'll let you look through the boxes.
Offline T Lea
Re: Starter
« Reply #2 on: July 01, 2010, 10:34:37 PM »
I almost always get my starters that way. I once pulled a C8 Cobra Jet starter out of a rebuilt starter box. Could have ended up in a 79 F250 if I hadn't been there  ;D
Offline C5ZZ
Re: Starter
« Reply #3 on: July 19, 2010, 11:51:35 PM »
If your starter has the correct numbers why
don't you just replace the nose? You can get
another starter for parts and switch the nose
portion.
MCA # 00945
Rangoon Red/Red Interior
Offline sparky65
Re: Starter
« Reply #4 on: August 13, 2010, 10:13:49 PM »
portion.
That sounds like a good idea but any idea what would be the correct numbers for a 67 6cyl auto?
Also can I copy this post when detailing it or should i start a new topic? http://www.concoursmustang.com/forum/index.php?topic=334.0
Steve
2009 Black GT Coupe
Re: Starter
« Reply #5 on: August 14, 2010, 01:11:51 AM »
.........Also can I copy this post when detailing it or should i start a new topic? http://www.concoursmustang.com/forum/index.php?topic=334.0
You will be save IMHO at following those details for your application ;)
Offline rockhouse66
Re: Starter
« Reply #6 on: August 14, 2010, 08:22:09 AM »
Maybe it doesn't matter since the exposed edges get painted anyway, but what do you use for the paper "gasket" under the band?  The original stuff appears to be a waxy brown paper of some sort?
'66 GT FB
Re: Starter
« Reply #7 on: August 17, 2010, 01:29:45 AM »
You might try butcher paper if they still make and use that stuff -
