Author Topic: 1969 parking brake handle  (Read 4688 times)
Offline Bullitt1977
« on: August 22, 2016, 07:55:28 AM »
Hi guys !
as remember : i've an early 1969 ( august 1968 ) my parking brake has been fixed by a previous owner , i found a used one in good condition , but the handle is different
Here are two pictures : the black one is in the car , the chrome one is the replacement one.
my question is have you some "black plastic " one in your cars ? i'm correct to think that early 69's could have this one and the chrome one arrived after?
thanks for your answers.
Guillaume
« Last Edit: August 22, 2016, 07:58:15 AM by Bullitt1977 »
1969 GT SPORTROOF
351 W 4V , TOPLOADER
Metchuchen 08/30/1968
Re: 1969 parking brake handle
« Reply #1 on: August 22, 2016, 10:47:32 AM »
Chrome 9/19/68 Metuchen, Mach 1, 63C.  Brian
« Last Edit: August 22, 2016, 11:45:30 AM by Brian Conway »
Offline Bullitt1977
« Reply #2 on: August 22, 2016, 12:32:51 PM »
Thanks you Brian, seems to be another version : the chrome one , but painted black ..
thanks
other example ?
regards
guillaume
1969 GT SPORTROOF
Offline Vcode
« Reply #3 on: August 22, 2016, 01:15:02 PM »
1969 is chrome and 1970 is black.
« Reply #4 on: August 22, 2016, 06:50:12 PM »
2 size threaded rods & bends on the shaft along with 2 sizes of threaded hole in chrome 69 handles black plastic replaced the chrome handles somewhere in the 70 run on later 70 cars. there is a date code on the assembly down by the pedal
Offline Vcode
« Reply #5 on: August 22, 2016, 09:50:53 PM »
Ed,
I checked the MPC and there is three listed as you mentioned for the 69-70's
1969 C5AZ-2750-A
1970 C9ZZ-2760-A "Before 1/5/70"
1970 D0ZZ-2760-A "From 1/5/70"
The chrome handle in my May 69 looks just like the one that was in my dad's 65 Galaxie 500.
« Reply #6 on: August 22, 2016, 11:54:41 PM »
that's because the chrome handle was sold separately under a c5az #& is a 65 galaxie part originally & I took many off parts cars in yards out west rustfree
Offline Bullitt1977
« Reply #7 on: August 23, 2016, 02:43:10 AM »
hi ! thanks for all this answers ,
sorry my english is not perfect , so if i resume the chrome one is the older , then  they changed for the black painted one, and finally in may 70  for the plastic black one? am i correct ?
if i'm correct , for an august 68 car i should have the chrome one ? true ?
another question ( sorry for my lack of knowledge ) what is MPC ( manual parts something ? ... )
regards
guillaume
1969 GT SPORTROOF
Offline Dirk Pitt
« Reply #8 on: August 23, 2016, 07:07:41 AM »
MPC is Master Parts Catalog.
1969 Mustang SCJ (W-code), Dearborn Built 4/21/1969
1969 Mustang CJ, Dearborn Built 7/16/69
« Reply #9 on: August 23, 2016, 11:22:27 AM »
Chrome knob with thin handle rod( early production) then chrome knob with thicker handle rod then late 70black plastic knob with thick rod.  Never a black painted knob.  Its mainly the rod on early cars as it was too thin & often broke or bent where it was attached to the pedal assembly. So ford changed to a thicker diameter handle rod & changed the angle of the rod bend to strengthen the pedal release set-up.  Problem is when finding the chrome c5az knob for a 69-70 mustang & cougar park brake assembly you have to have the chrome knob to match the threaded rod diameter. Ford used the same chrome knob but the threaded hole in the chrome knob was the next size bigger threaded hole to use on the bigger (or thicker) rod on the improved version.
Offline Vcode
« Reply #10 on: August 23, 2016, 06:40:54 PM »
Ed,
Is the C9ZZ handle chrome or black plastic?
Here's the C5AZ & the DOZZ handles
« Last Edit: August 23, 2016, 06:43:25 PM by Vcode »
« Reply #11 on: August 23, 2016, 08:43:29 PM »
it would be chrome as the dozz is  the only plastic knob  but t he whole pedal assembly is c9zz # with chrome knob & the dozz# is on the whole assembly with the black plastic knob.
Offline Vcode
« Reply #12 on: August 23, 2016, 10:17:00 PM »
ok - thanks.
Offline Bullitt1977
« Reply #13 on: August 24, 2016, 02:51:31 AM »
Thanks a lot for all these explanation specialed and Vcode
so i find a C5AZ , which seems to be correct with my car , just do you recognize where did come from my black plastic handle i've on the car for the moment ? it didn't look like the D0zz
thanks also for the vocabulary with MPC DIRKPITT007 (uhm did you work for the NUMA ???    ;D   )
regards
guillaume
1969 GT SPORTROOF
« Reply #14 on: September 20, 2016, 08:45:18 PM »
These came up at work today.
The C5AZ-2760-A chrome handle has 12-24 threads.
The C9ZZ-2760-A chrome handle has 1/4-20 threads.
The D0ZZ-2760-A black plastic handle has 5/16-18 threads.
The D???-2760-? black plastic has no threads, but press fit onto the knurled rod end. Have one example of this in the yard, plus my customer had one too. I am thinking service replacement?
